Another Tire Question....
1. Somewhere I read that there were only two types of tires in the "run-flat" group that were repairable, able to be plugged etc. when there is damage. Do you know what brands they are?
2. My original tires are; GoodYear Eagle F1; 245/45z R17 (front) and 275/40z R18 (rear).
A. Can I put those tires on new wheels that measure;
17 X 9.5 (front) and 18 X 10.5 (rear) ???
3. If I wanted to move up to 18" fronts and 19" rears, what would be best size "wheel" to buy to put them on?
I know this is a long winded question and I appreciate everybodys experience and advice.
So they didn't answer your question....it's a little more complicated than some of the other But I will try to answer some of the questions to the best of my ability - okay?
I believe the Goodyear is the only one that can be driven with zero air pressure for 200 miles and can be repaired. I believe the others like the Michelins - if driven on with zero pressure, the tire has to be replaced.
According to Michelin's web site - the largest wheelp for a a P245-45x17 is a 9" wheel. I suppose that you could try to stretch your stock sized EMT over that wheel - but remember that the sidewalls on that tire are exceptionally stiff and hard to work with. I don't understand why you'd want to do that. If you're planning on getting new or different wheels, save your money until you can afford the appropriate sized tires to go with them.
A lot of guys go to a 9.5" wheel in front and a 10.5" wheel in back. My suggestion would be to do a little shopping, figure out what you can afford and find a wheel that you like. Once you have a specific application in mind, chances are someone here has already done it or something similar to it.
In the mean time, here are a couple of web sites for you to ponder and go through that might answer some of your questions....
http://www.michelinman.com/catalog/index_3.html
http://www.tires.com/
http://www.tirerack.com/
http://www.goodyeartires.com/
http://www.bfgoodrichtires.com/bfgap...og/index_2.jsp
http://www.kumhousa.com/
That should get you started.....
Also a plug is not a proper repair for any speed rated tire. See the following: Puncture Repairs The Right Way
