Rusty Rotors
Old Mar 29, 2005 | 10:40 PM
newyiddy20's Avatar
newyiddy20
Default Rusty Rotors
did you have them ? what did you do to get rid of the rust ?
Old Mar 29, 2005 | 10:42 PM
mcarota's Avatar
mcarota
How long has it been sitting. Usually they clean themselves up the first time you hit the brakes while driving if they are rusty from sitting for a few hours....days.
Old Mar 29, 2005 | 10:45 PM
CUlookin's Avatar
CUlookin
They are cast iron and will rust like 10 minutes after they get wet... Take the car around the block and they'll be good again!
Old Mar 29, 2005 | 10:52 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
It won't hurt them, they just look like crap
Old Mar 29, 2005 | 10:57 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Paint the rotors with a good quality high temp paint, and only the fire path will show rust till the first time its driven.
Old Mar 29, 2005 | 11:05 PM
TruUndrtkr's Avatar
TruUndrtkr
the rotor hats is what i have a problem with...
Old Mar 29, 2005 | 11:31 PM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
Yeah, I had my ride sitting up for awhile after I washed it and there was the rust. I freaked, but I figured I've had it for a few months it's not like it just appeared on this day. I drove it and the brake pads wore 'em right off. They look like the same stock crap again
Old Mar 29, 2005 | 11:34 PM
DeeGee's Avatar
DeeGee
Old Mar 29, 2005 | 11:58 PM
Z0SLIK's Avatar
Z0SLIK
Paint them or buy covers from WCC.
Old Mar 30, 2005 | 12:03 AM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
(Except Ecklers has a better price on them..... )
Old Mar 30, 2005 | 12:08 AM
X-ZZ4's Avatar
X-ZZ4
Before.....
After....
Old Mar 30, 2005 | 12:42 AM
TruUndrtkr's Avatar
TruUndrtkr
think i'll try to paint them....that will hold me over until i can replace the rotors with what i really want..
Old Mar 30, 2005 | 01:23 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
My Baers do the same. Just drive for a bit and problem solved.
Old Mar 30, 2005 | 02:20 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
After painting them a couple of times this was my answer. At least I am hoping the zinc coated rotors will do the trick.
Old Mar 30, 2005 | 02:35 AM
TruUndrtkr's Avatar
TruUndrtkr
i was under the impression that this was not supposed to occur with the baers...this happened to a friend of mine, and he was highly upset...
Old Mar 30, 2005 | 02:36 AM
TruUndrtkr's Avatar
TruUndrtkr
those look good...real clean look...
Old Mar 30, 2005 | 06:18 AM
The stock rotor hats will rust after a period of time. You can paint them with the same type of paint you would your calipers and they will look much better. Or you can get some covers that go over the hats - check out Ecklers for a set. They have red ones on sale I believe.
Old Mar 30, 2005 | 06:21 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Rotor Hats......
Old Mar 30, 2005 | 07:17 AM
SlideRulz's Avatar
SlideRulz
Check with Evil Twin, he knows how to clean them up.
To Rusty Rotors
