Replacing Side Markers Link
Old Apr 9, 2005 | 04:00 PM
Snake11eyeS's Avatar
Snake11eyeS
Default Replacing Side Markers Link
Could someone post the tech tip link on how to replace the side markers. Thanks
Old Apr 9, 2005 | 04:39 PM
DeeGee's Avatar
DeeGee
Haven't seen a tech tip but I replaced mine with ambers.
I unscrewed the outer brake light on each side (toex screws). You then need to reach in to get at the unit. The bulb holder unclips with a turn. Unscrew the nuts on the screw threads that hold the marker on. Its a long reach and a bit fiddly. Can't remember the wrench size.
Reinstalation is the reverse. Looks good but takes a bit of time. Its also more of a fiddle on the Vert on the passanger side as the antenna is in the way.
Best of luck.
Old Apr 9, 2005 | 04:49 PM
Dr. Dan's Avatar
Dr. Dan
Best of luck.
I pulled the wheelwell liner for access to the Pass. side. Was easier that way since i already had the wheel off.
To Replacing Side Markers Link
