(Poll) What Display Do You Use?
Apr 11, 2005 | 07:36 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I start by monitoring my cold tire pressure to make sure they are at 30 psi. Then switch to oil temp.
I like to check it all out and always have something on the DIC but most of the time it’s the oil temp.
Apr 11, 2005 | 07:43 PM
St. Jude Donor '11
Well lets see, I start with the fuel range, then oil pressure, then odometer, then over to tire pressure,
then back over to fuel range, next avg. speed, then batt volts, then after that oil life, then elapse time,
then coolant temp, and maybe trans. temp. and finally back to elapse time...ok just kidding I'm an odometer guy...hehe
Apr 11, 2005 | 07:45 PM
I've got mine on scan.
Apr 11, 2005 | 07:57 PM
I like seeing how many miles my baby has on it!
Apr 11, 2005 | 08:25 PM
I have my Coolant Temp. on most of the time.
Apr 11, 2005 | 08:27 PM
I leave it blank because I don't want to see the mileage racking up.
Apr 11, 2005 | 09:28 PM
Odometer.
Apr 11, 2005 | 09:35 PM
OIL PRESSURE,,,OIL PRESSURE,,, OIL PRESSURE...
You have no immediate need to know about the state of your fuel level...
You have no immediate need to know what the voltage is...
However if the oil pressure fails...
GAME OVER!!! GAME OVER!!! GAME OVER!!!
nuff said...
yr hmbl svnt
Apr 11, 2005 | 09:44 PM
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Quote:
Originally Posted by MY1STPEWTER
Oil temp until I know it's good and warmed up. Then I'll check the tire pressure's after I've been driving awhile. Then most of the time just put it back on oil temp unless I'm just checking everything else out.
Exactly what I do.
Apr 11, 2005 | 09:45 PM
Quote:
Originally Posted by Red_Racer
Exactly what I do.
Same here.
Apr 11, 2005 | 09:46 PM
Quote:
If only there was a way to have it scan each display/function for 3-10 seconds...
That would be great. Anybody out there able to hack into the system and make it happen??
Apr 11, 2005 | 09:48 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
Trans Temp. Everything else I get from the HUD.
EG
Apr 11, 2005 | 10:30 PM
Oil temp - because I like to know when the engine is ready to catapult me into space!
Apr 12, 2005 | 12:22 AM
Oil temp till warm, then inst fuel for kicks.
Apr 12, 2005 | 12:27 AM
Quote:
Originally Posted by 98silvermine
Mine stays blank. That way, I will be likely to see any warnings if they appear.
Apr 12, 2005 | 12:41 AM
Quote:
Originally Posted by Avanti
Oil temp because it is the only available engine function not otherwise displayed.
Quote:
Originally Posted by KernelDee
Average MPG after everything is warmed up
Apr 12, 2005 | 12:43 AM
Quote:
Originally Posted by Blue Lion
Nothing most of the time; when I want to check the display, I scroll through all the options and then return it to the blank screen.
Apr 12, 2005 | 01:13 AM
Quote:
Originally Posted by screw991le
I use the oil temp until the car reaches over 150. So I know it is real safe to get on the gas.
That's why I watch it too. I wish we had a DIC screen for KR so I could monitor my tune for serious problems without having to hook up my laptop.
Apr 12, 2005 | 03:16 AM
What he said. If something does pop-up I want to see it then.
