Windseld Heads up display
Old Apr 14, 2005 | 07:41 PM
2079's Avatar
2079
Default Windseld Heads up display
I just had my windshield repaired " a rock ". I was informed that if I was to replace the windshield with heads up display it was almost double the cost.
I remember reading a thread were you could install heads up on your car as a kit although you did not have to change the regular windshield.
QUESTION if I ever do have to replace the windshield can I just use a regular windshield?
Old Apr 14, 2005 | 07:49 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I stand corrected......I just looked it up on GMPartsDirect......
No HUD = $271.42
HUD = $794.03
Old Apr 14, 2005 | 08:11 PM
Sorny's Avatar
Sorny
Do you carry full coverage insurance?
If not, you should. No cost glass is a VERY desirable insurance option (should be part of your comprehensive coverage) on the C5...
Sorny
Old Apr 14, 2005 | 08:19 PM
michach1's Avatar
michach1
I installed the HUD in my car without changing the stock windshield. No problems seeing the display at all. Save the money.
Old Apr 14, 2005 | 08:24 PM
rac03's Avatar
rac03
someone must know what the difference between the two windshields is. I would be interested if anyone knows.
Old Apr 14, 2005 | 08:27 PM
VetteDawg's Avatar
VetteDawg
I also added HUD and it looks just fine with my non HUD windshield.
Old Apr 14, 2005 | 08:37 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
The HUD is suppose to be more reflective. If you look at them side by side, esp. in the right light you can tell a slight difference. If the $$$ is coming out of your pocket I think you'll be perfectly happy with a regular windshield. If the insurance company is paying, make them buy you the HUD one
Old Apr 14, 2005 | 08:47 PM
Red86Cfour's Avatar
Red86Cfour
My C5 had the windshield replaced before I got it. I strongly suspect that non-hud glass was installed. No complaints.
Old Apr 14, 2005 | 09:07 PM
2079's Avatar
2079
Many thanks for the repliies.
Bottom line , lots of money for very little difference. I will save my noney if I ever have to replace it and will buy a regular one.
Old Apr 14, 2005 | 09:34 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I was told that the HUD winshield is slightly staggerd.....The wind shield is made up of two pieces of glass with a sheet of film in beetween to bond them (safety glass construction) to keep the HUD display sharp the safety film at the bottom is a little bit thiker at the bottom to align the reflection of the HUD thrue both sheets
Old Apr 14, 2005 | 09:41 PM
That's the way I would do it too.
Mike Mercury's Avatar
Mike Mercury
this is 100% correct. And that's all the difference there is supposed to be The uneven safety film is to reduce the "paralax" effect.
Old Apr 14, 2005 | 10:15 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
To Windseld Heads up display
