Installing an Optima Red Top
Old May 7, 2005 | 10:58 AM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Default Installing an Optima Red Top
I am going to be picking up my 00 soon.. there is an ac delco 1809 in there now, but am gonig to replace it with the red top. Obviously car will be off and all.. but after i disconnect and remove old battery and then put in the new red top, is there problems like will the stereo need a code rentered? Anything else i should be concerned, cautious about? or drop it in and im good to go!
Old May 7, 2005 | 11:05 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Drop it in and your good to go. I just installed an Optima Red Top 2 weeks ago.
Old May 7, 2005 | 11:11 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
If the security code has been set on the radio, you'll have to enter it once the battery is hooked up or your radio will not work. I'd be more concerned about the Red Top battery working properly. My opinion (for what it's worth) is the Optima Red Top battery is a less that reliable piece of horse poop. Good luck w/ your purchase. Hope you have better luck than I've had w/ Optima batteries.
Old May 7, 2005 | 11:25 AM
BlownV6's Avatar
BlownV6
You're one of few who think that. I've had a red top in my C5 for 2 months. No problems
Old May 7, 2005 | 11:44 AM
There is a possibility that you will need to reenter your theft lock code for the radio, but you may be able to make the swap without it. I'd have it handy just in case.
Old May 7, 2005 | 11:45 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Originally Posted by JDs00PewterCoupe
There is a possibility that you will need to re-enter your theft lock code for the radio, but you may be able to make the swap. I'd have it handy just in case.
You can simply disable your Radio security before you disconnect the battery...here's the instructions
https://www.corvetteforum.com/techti...=164&TopicID=1
Originally Posted by techtips
Procedure: 01. Turn the ignition ON (The radio displays LOC) 02. Hold down the Radio Presets 2 and 3 buttons for six seconds 03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step. 04. Press the AM/FM button 05. The radio display changes to another three-digit number. Write this number to the right of the first one. 06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05 07. Call 1 800 537 5140 08. Press 1 then # (pound). You’ll hear “Invalid Code, try again” 09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start) 10. Enter the number from STEP 6 then * (star) 11. Listen to the four-digit number and write it down. It will be repeated twice 12. Turn the ignition ON (The radio displays LOC) 13. Use the MN and HR buttons to enter the code from STEP 11 14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code. Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due). I verified it on an Y2K C5 with a locked radio - mine.
Old May 7, 2005 | 11:50 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Old May 7, 2005 | 12:07 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
what are the odds the radio will enter ask for a code? I have an aftermarket headunit.. does that change anything? Its an alpine cda 9805.. thanks
Old May 7, 2005 | 12:32 PM
rickko's Avatar
rickko
... My opinion (for what it's worth) is the Optima Red Top battery is a less that reliable piece of horse poop. ...
I don't know about that but I do know the Optima requests a their batteries be checked for 12.6v every 6 mos. and given a full bench charge if it falls below that reading.
..rickko..
Old May 7, 2005 | 12:41 PM
StingR's Avatar
StingR
I am in need of a new battery and was planing on the Optima but have read too many negatives lately. Look into "Exide Orbital" sealed battery before making your decision........
Old May 7, 2005 | 01:12 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
i heard a bunch of good things and some bad.. but like ne battery the bad will happen to people.. but overall it is a great battery i think. What else do people use and have been happy with?!?
Old May 7, 2005 | 01:22 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've had an Optima Red Top 75/35 for 18 months - not a moment's problems and that's going through a Phoenix summer. Over 100 days of 100 degrees or more last year. My car is black and the underhood temps reach well above 200 degrees. No problems.
There have been some CF'ers who have reported failures. But like they say in Rome - Caveat Emptor (buyer beware.....)
Old May 7, 2005 | 01:24 PM
WOEII's Avatar
WOEII
From: [QUOTE=onedef92]Remember when that spookable closed the door on that mofo and trapped him inside tha
St. Jude Donor '06 thru '11
Don't drop your only socket attachment. Mine is still rollin around somewhere. :o
Old May 7, 2005 | 02:43 PM
DeeGee's Avatar
DeeGee
The stock battery hold down doesn't fit the Optima. I think you can get a bracket specifically for the Red Top from Optima. I made a local bracket but I may have to get the real thing to hold it down tighter.
I've had mine for 6 months and its doing great.
Old May 7, 2005 | 02:59 PM
Lancer033's Avatar
Lancer033
I replaced my optima last weekend (left the radio on for too long while working on the car, easier to pick up a new one than recharge it) accidently dropped a wrench and it went under the battery tray. had to take out the battery tray, and piece of plastic in the behind the wheel. More annoying than anything else, but it is a pain if you drop something.
There have been some bad reports about optimas over the last couple of month, but I think they are a small % of the people that are using them with no trouble. Even with the recient problem, they're still 100x better than a Delco AGM POS.
Old May 7, 2005 | 03:11 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
My Red Top went in 7 months ago.....its fantastic and the car fires like it never did, very good unit IMO
Old May 7, 2005 | 03:16 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
what size/ kind do I need for a 2000 c5 ? I know there are a few numbers that you can choose from... what are pple saying they dont fit in?
To Installing an Optima Red Top
Old May 7, 2005 | 03:20 PM
blacksedan87
There are two that fit the C5 - the 75/35 which is 720 cold cranking amps and the 34/78 which is 800 CCA. The 34/78 is slightly larger and can be distinguished by the side terminals being closer together than on the 75/35.
Old May 7, 2005 | 03:42 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
for a NJ resident what would be suggested?
Old May 7, 2005 | 03:46 PM
RCK1999's Avatar
RCK1999
How about moving!
