Blinking Third Brake Light
Old May 8, 2005 | 12:15 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Default Blinking Third Brake Light
Anyone know a source for this option...third light blinks several times then goes to a solid brake light.
Thanks!
Old May 8, 2005 | 12:27 PM
GRT1TODAY's Avatar
GRT1TODAY
Got mines a few years back from thelapd.com
Old May 8, 2005 | 01:08 PM
donnyonee's Avatar
donnyonee
do a search for it, its been a multiple post already, i have 1 but dont remember .
Old May 8, 2005 | 01:10 PM
VetteSiNz's Avatar
VetteSiNz
Thanks!
Here's the site: http://webelectricproducts.com
Old May 8, 2005 | 03:09 PM
Merlin02's Avatar
Merlin02
You may want to check the vehicle code in your state before you install one. Here in California, a "deceleration light" cannot blink more than 4 times before it remains on solid, and it cannot blink more than 4 times within four seconds.
Old May 8, 2005 | 03:41 PM
leaftye's Avatar
leaftye
Geez, leave it to Cali to regulate the smallest thing, but they'll still let guys plug each other in the rear.
Old May 8, 2005 | 04:24 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
That's news to me, but if you say it's in the VC I'll take your word for it. I can just see getting pulled over for my brake light pulser.
KC Vette-
I got mine from LAPD, it plugs right in unlike the webelectric pulser which has to be spliced in. I bought the webelectric one first and then found out about the plug in version by LAPD and went with theirs.
Old May 8, 2005 | 04:28 PM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
I got mine from thelapd.com as well, good product!
Andy
Old May 8, 2005 | 06:14 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Thanks for all the info, got a good starting point..
Old May 8, 2005 | 07:47 PM
Kris072's Avatar
Kris072
Got one from web electronics too.. even with an hour on the phone and step by step help it just wouldnt work. Have a feeling its the car and not the product. Got this one http://autoelectronicupgrades.com/b%...ll/install.htm and it was a simple plug and play and no splicing. It's adjustable
Old May 8, 2005 | 08:01 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
That's what happens when you make fun of me.
Old May 9, 2005 | 10:55 AM
PepFontana's Avatar
PepFontana
Got mine from LAPD.com also and it is capable of being set to different amount of "blinks" and also different speeds for the "blink"
Old May 9, 2005 | 11:05 AM
Kris072's Avatar
Kris072
A. its so easy
B. I'm the one who paid less remember ?
tag yer it
Old May 9, 2005 | 11:25 AM
DaBoz's Avatar
DaBoz
Really??? Damn... mine is set to 14 blinks.
Yep....
Deceleration Warning Lights
25251.5. (a) Any motor vehicle may also be equipped with a system in which an amber light is center mounted on the rear of a vehicle to communicate a component of deceleration of the vehicle, and which light pulses in a controlled fashion at a rate which varies exponentially with a component of deceleration.
(b) Any motor vehicle may be equipped with two amber lamps on the rear of the vehicle which operate simultaneously with not more than four flashes within four seconds after the accelerator pedal is in the deceleration position and which are not lighted at any other time. The lamps shall be mounted at the same height, with one lamp located on each side of the vertical centerline of the vehicle, not higher than the bottom of the rear window, or if the vehicle has no rear window, not higher than 60 inches. The light output from each of the lamps shall not exceed 200 candlepower at any angle horizontal or above. The amber lamps may be used either separately or in combination with another lamp.
(c) Any stoplamp or supplemental stoplamp required or permitted by Section 24603 may be equipped so as to flash not more than four times within the first four seconds after actuation by application of the brakes.
Amended Ch. 410, Stats. 1983. Effective January 1, 1984.
Old May 9, 2005 | 11:38 AM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
Also got mine from LAPD.com ....installing it and adjusting it was a first as it's the only time my wife has sat in the driver's seat
Old May 9, 2005 | 11:39 AM
MyVetteDream
A. its so easy
tag yer it
A. Can't/won't deny it.
B. And look what happened?! How much more time & headaches? Then you got the same one I did Love your taste.
Old May 9, 2005 | 11:49 AM
Kris072's Avatar
Kris072
I"m still ahead no matter how you look at it
To Blinking Third Brake Light
