Alignment HEADACHE!!!.... need advice!
now, although the guy that finshed the alignment seemed to know a little bit about what he was doing, i still need some advice from anyone that can help!!
they tried to explain to me that it was impossible to get my car completely aligned. they said something about needing a "caster kit/bolt" for the front in order to complete the alignment???
here are the numbers:
LEFT RIGHT
CAMBER: -0.8 -0.2
CASTER: 8.8 8.3
TOE: -0.04 -0.06
TOTAL TOE: 0.02
STEER AHEAD: -0.05
my PROBLEM is that now (only after leaving there) i have a bad pull to the right. now if anyone can explain this to me i would really appreciate it. the shop wants me to bring it back there, but they are on drugs and i will never return there!
im hoping to get another shop to help me out. anyone have any ideas as what to do?!? im pretty frustrated now, as its kinda sucky to drive the car like this!!
appreciate any info! sorry so long!
my guy at just tires dials mine in so carefully, making sure even that a subsequent adjustment hasn't influenced the previous one. for example, after he finishes the camber adjustment and moves on to caster or toe and does that one, he will go back again and loosen the camber cam a little to make sure there isn't some funky preload going on that will screw things up). and the differences from side to side are in the second decimal place.
it takes him about 2 hours but it's well worth it.
Bottom line is that your alignment shop sucks. They don't seems to understand that adjusting one setting affects the other settings, and that changes have to be made slowly and rechecked. They're not doing that, and that's why your alignment settings are all over the place. I suggest talking to local racers and find out where they get their alignments done.
http://www.autocrossforum.com/forums...5&hl=alignment
http://www.autocrossforum.com/forums...1&hl=alignment
http://www.autocrossforum.com/forums...3&hl=alignment
BC
That sucks, I hear its really hard to find a good alignment shop around our area. I know I should get one but Im dreading it. Did you call Chris, if I recall correctly i think he got an alignment not to long ago. He said the guys that did his were really careful, he seemed to be happy with it. Other than that I dont know who I would recommend. Good luck.
Later,
Max
Later,
Max
Chris
Chris
Later,
Max
Chris
Chris
Seafood???
And I'm getting ready to go put a new AC belt on.
I need to get my car re-aligned too. Mores Car in Melbourne seem to know what they doing, I hope. Anyone running Z06 specs?
Fred! All you can eat sea food in Kissimee 4:00 tomorrow afternoon, we're going for Brians 21st birthday which was last tuesday!
Chris
i ended up bringing the car to firestone on 436/ + 17/92. i actually called corvette masters, and they told me they send out all their vettes to firestone for wheels/tires alignment. so i figured i should be in good hands.
went there, and they were expecting me, i had already called up. got me on the rack within 15 minutes. i spoke with the tech working on the car, he was an older guy that said he had been doing vettes for the area for 10 years. he gets all the customs from corvette masters, and also rogers etc.
the tech could not believe what a shotty job the other shop did. the whole car was off, and.... they even left bolts LOOSE!!!!!!!
yes, you read that correct!! the tech actually could finger turn the bolts
so they fixed the car to Z06 spec and everything is now fine. they charge 59.99 for 1 alignment, or 119 for lifetime. so i went with lifetime. great place to do business with. they actually documented everything the other shop messed up, that way if i have problems when i dispute the charge with them and the credit card company!!!
back on the road again!! everyone local... seafood tom. at 4. most will probably meet at chris's house, them to my house. hope to see some of you there!
