Vert question?
Old May 15, 2005 | 08:34 PM
bierbelly's Avatar
bierbelly
Default Vert question?
Hi all. A little info please. I was dropping the top tonite and noticed that the wire leading to the rear window defogger had come undone. Looked around, couldn't find the receptacle for it. Anyone know where this plugs in?
Thanx
Old May 15, 2005 | 08:39 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
was it the end that goes onto the window?
Old May 15, 2005 | 08:44 PM
bierbelly's Avatar
bierbelly
Nope, other end. The plug is still on it, but I can't find where it plugs into to run to the chassis/power.
Old May 15, 2005 | 08:48 PM
onmyelectraglide's Avatar
onmyelectraglide
the other end is behind the seat belt mount cover. you will need a 15mm socket to remove the belt then remove the cover and you will see the connector attached to the back of the cover.
Old May 15, 2005 | 08:50 PM
Dr. Dan's Avatar
Dr. Dan
Open the little trap door where the top frame connects. There is a plug in there...somewhere
Old May 15, 2005 | 08:55 PM
bierbelly's Avatar
bierbelly
Many thanks!
Old May 15, 2005 | 10:53 PM
GrayC5's Avatar
GrayC5
Good luck with the fix.
Old May 15, 2005 | 11:18 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
That's a nice little tid bit to remember.
To Vert question?
