CCW wheel weights
Old May 24, 2005 | 05:01 PM
AU N EGL's Avatar
AU N EGL
There is an old saying:
"taking off each 100 lbs of your car or body fat is like adding 10 HP. " weather this is true or not I have no Idea.
Also smaller diameter wheels are faster. One local shop did a few before and after dynos on stock vette wheels then with 19" wheels. the 19" wheels were 12-15 HP LESS do to the size. Big may look cool , but for get the HP and acceleration.
Old May 24, 2005 | 05:39 PM
Darion's Avatar
Darion
AU N EGL,
Thanks for the reply and the info. I don't know about the 100 pound rule that you outlined but there are a few factors to consider when changing wheels and tires, IMHO. Weight is one issue which is what this thread was all about. Next is overall rolling diameter. This is not only a function of wheel size, 18 vs 19, but also the tire that has been mounted. Reducing sidewall profile from say a 40 to a 35 can compensate for the fact that a larger wheel diameter is being used. It would be interesting to know if those dyno numbers were the result of weight, taller tire or a combination of both.
Thanks agian,
Darion
Old May 24, 2005 | 06:48 PM
AU N EGL's Avatar
AU N EGL
Thanks agian,
Darion
Both.
Depending on the rim size and width of tire you wish to use would determine the profile.
I use 18" all around. My street wheels are 18x10f with 275/35x18 Mich PS 18x11r with 335/30x18
Track 18x11f and 18x12 rear with 25.5x11.5x18 ( fricken american sizes ) or about 310/33x 18.
I have also used 285/30x18 fronts on the track.
Dont go larger then a 40 series on the front. 35 series front and 30 series would be my choice for rears. Of course this all depends on the width you are looking at and what tires you can get.
Old May 24, 2005 | 06:57 PM
YO-EL's Avatar
YO-EL
[QUOTE=AU N EGL]Ohhhh I think there is a big difference in acceleration do to the un-sprung weight difference.
Maybe so, but not with 10 lbs difference....
Our friend Darion is posting about the weight difference in street CCW rims...
For you other questions..
You can't have the rims , because they were just sold to CCONKLIN1.
PM Chris if you want them.. I don't think he even put them on his car yet, as he might be having some engine issues....Worth a shot..
I never use those at the track.. drag radials only...
And yes, the head unit is a Kenwood..
I've had it since Dec 1999 when I got my car..
I like it alot.. Good luck to you.
Ellis
Old May 24, 2005 | 07:28 PM
Z06_Performance's Avatar
Z06_Performance
I should of looked here before posted my thread.. But does anyone have a ccw website link?
Old May 24, 2005 | 08:07 PM
95wht6spd's Avatar
95wht6spd
10lbs is something like 4x that amount when it is unsprung weight. So in effect it would be something like 160 lbs. on the whole car and it would affect acceleration, stopping, and suspension performance.
Old May 24, 2005 | 08:10 PM
AU N EGL's Avatar
AU N EGL
http://www.ccwheel.com
Old May 24, 2005 | 09:29 PM
Face's Avatar
Face
