Courtesy light problems
Old Jun 2, 2005 | 11:37 PM
Ham3919's Avatar
Ham3919
2nd Gear
Default Courtesy light problems
Hi all, I'm new to the group and just purchased a 98 M6 a few months ago. I had something strange happen and thought I would see if anyone has had a similar problem. One evening I opened the door but none of the courtesy or reading lamps came on. I tried to turn them on using the panel brightness control but that didn't work either. I've switched out the micro relay in the fuse box with another but still no luck. The strange thing is that I can turn on each reading lamp with the switch so it's getting power. Any ideas on what I could try next? I figure you guys are smarter than any dealer could be. Thanks for the help.
Old Jun 3, 2005 | 11:01 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
You switched out the relay or the #11 fuse in the pass. foot well?
Old Jun 3, 2005 | 06:14 PM
Ham3919's Avatar
Ham3919
2nd Gear
You're right, there are a couple of blown fuses that I found. Once I replaced them it works fine. Thanks for your help.
Old Jun 3, 2005 | 06:24 PM
csexton's Avatar
csexton
This forum is great, isn't it!
Old Jun 3, 2005 | 08:26 PM
MyVetteDream
Glad it worked ...
Just don't ask how I knew :o
To Courtesy light problems
