Usb In A Vette
Old Jun 4, 2005 | 07:44 PM
AlanN's Avatar
AlanN
Default Which cable to connect an iPOD?
Anyone know which cable to use on this site to connect iPOD to the factory radio in an 04 Coupe with CD player?
http://www.installer.com/aux/
Old Jun 4, 2005 | 08:29 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Not sure on that page. I would think that the GM-10 Aux is the one on that page but it looks different than the one in the link I posted below. This one will work:
https://www.litewarehouse.com/catalo...roducts_id=221
Paul
Old Jun 5, 2005 | 09:23 AM
Lowcash's Avatar
Lowcash
I am not sure about wiring directly to the head unit, but I bought an adaptor from . It connects to the stock cd changer in the rear hatch. It works ok, has it quirks but i'm definatley satisified with it. It also charges the iPod while the car is off.
Old Jun 5, 2005 | 09:43 AM
Freestyler's Avatar
Freestyler
ipod2car
thats what you need or icruze
the ipod2car is cheaper and connects easily as unplugging cable from cd-changer unit in the boot, and taking that cable and attaching it to a 'gender bender' (GM-10AUX or something cable $20) -- then the ipod2car easily connects to THAT cable
... from there its a snap, the ipod2car has a nice long lead and a connector that fits miniIpod or the biggies...
perfect
plus your ipod does the equalising... 12 band or so - by song, genre, albumn etc -- no need to **** about with the 'bass, treble' ***** anymore
Old Jun 5, 2005 | 02:11 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
http://www.mp3yourcar.com/search.asp
Old Jun 5, 2005 | 06:01 PM
Kris072's Avatar
Kris072
If you have the 12 disc changer you need the GM-10 Aux. (it's called a PIE)
One of our supporting vendors can help you. Tuan Le is awsome !
There were extensive threads a while back on installing an iPOD. Here is one of Tuan's posts. (PS I LOVE MY iPOD in my car !!)
To get great audio quality from IPOD (or any other MP3 devices) into your stock Bose system, you would need to get 2 items. The cd-changer wiring harness and the GM10-AUX adapters. The cd-changer wiring harness plugs into the cd-changer port on the passenger side footwell, and the GM10-AUX adapter plugs into the cd-changer wiring harness and coverts it over to RCA input port. From there, you can practically hook up any devices with stereo output.
CD Changer wiring harness = http://www.litewarehouse.com/catalo...products_id=223
GM10-AUX adapter = http://www.litewarehouse.com/catalo...products_id=221
Old Jun 5, 2005 | 06:15 PM
EscapePod's Avatar
EscapePod
Kris, do you recall if this arrangement would then "disable" the use of the 12-disc changer?
Old Jun 5, 2005 | 06:41 PM
AlanN's Avatar
AlanN
Originally Posted by screw991le
This one looks nice but I do not want to pay 189.99 for a cable Wife is pissed enough that I am buying an iPOD
Thanks for all the replies. This forum is great! I hope I can help someone as time goes on and I learn more.
Alan
Old Jun 5, 2005 | 06:45 PM
AlanN's Avatar
AlanN
I do not have the CD changer; just the head unit. Would I only need the one cable then? I know some of these questions may be simple but, I know NOTHING of electronics. :o
Old Jun 5, 2005 | 08:41 PM
Freestyler's Avatar
Freestyler
right you need both cables i would say since you dont have the cd stacker in the rear of the car
the cd-changer cable connects to the INPUT on the head unit
from there, you are just tricking it, by putting the gm-10-aux cable onto it, and then into the ipod2car....
You Wont look back .. i love having all the songs, without distortion...it rocks
Old Jun 5, 2005 | 09:34 PM
Kris072's Avatar
Kris072
If you have the 12 disc changer the PIE is the interface from the GM wiring harness to enable you to use RCA connections. There is no way to hook directly up to the head unit (if you have the stock BOSE system)
if you DONT have the 12 disc changer there is a different hook up procedure.
Email me and I'll see if I can help you out
To Usb In A Vette
