This is a stupid question..
Old Jun 17, 2005 | 09:16 AM
cowpunk's Avatar
cowpunk
Don't forget to rotate the air in your tires once a year!!!
XPLOCIV's Avatar
XPLOCIV
Originally Posted by vectorz
Do wheels weigh the same full of air, as they do without air?
I packaged up some rims w/ the tires mounted, and forgot to let the air out..
Should I open it and start over?
Not such a bad question after all......Look at all the different responses you got.
I'll admit, I didn't know the answer.
Old Jun 17, 2005 | 10:10 AM
rickko's Avatar
rickko
---> My answer: Depends if you replaced the Winter air with Spring, or Summer air.
---> A better answer:
When one asks a person: "What is air?", many times this answer is heard: "Nothing, or virtually nothing". Explain to the audience that air consists of small particles, molecules. Let the audience estimate how much the weight (mass) is of 1 m3 of air.
A glass bottle, that contains 1 liter of air, is placed on a balance. The weight is read from the display or scale.
The bottle is now evacuated and put on the balance again. The weight is read again.
Observe how the weight is diminished. The difference in weight, read from the scales, is about 1,3 g. When the air is admitted to the bottle again, the original weight reappears.
Explanation 1, 2 :
At the first measurement the total weight of the bottle and air together is determined.
Then, by means of a suction, the air is taken out of the bottle. When the bottle is weighed again, only the weight of the bottle itself is measured. The difference in weight is the weight of the air that was in the bottle. In this measurement the result is: the weight (mass) of 1 liter of air is about 1,3 g. As 1 m3 contains 1000 liter, the amount of air in a volume of 1 m3 is 1000 times as much as in 1 liter. So 1 m3 of air weighs about 1300 g, that is about 1,3 kg, which is rather substantial!
Got that? 1 cubic meter (~35.3 cubic feet) of air weighs 1300 grams or ~3 lbs.
---> Best answer:
You can use the Ideal Gas Law to determine the weight (mass) of the air in
your balloon. The law is
pV = nRT
The variables in this equation, with SI units are:
p - pressure (Pa)
V - volume (m^3)
n - moles (mol)
R - universal gas constant - 8.314 Joules / mole Kelvin
T - temperature (K)
If you solve for the number of moles, n, you can then use the following
relationship to calculate the mass:
m = nM
where
m - mass (g)
M - molecular weight (g / mol)
This mass is what a force must react against when accelerating the object
and is sometimes described as the inertial mass (per Newton's Second Law).
Now, if your ballon is filled with room temperature air (not hot), it may
not "feel" like it weighs the amount calculated by the above equations.
This is because it is surrounded by air and has neutral buoyancy. Also,
as you move it through the air, you will feel more resistance than would
be expected by its mass. This is because of the drag on the balloon by
the surrounding air.
Once you heat the air in the ballon, it will have buoyancy becuase it will
be less dense than the surrounding air. If you repeat the calculation
above, using the higher temperature, you will find there is less mass of
air in the same volume of balloon. Density is just the ratio of mass to
volume.
In the atmosphere, density decreases with altitude, so you hot air balloon
will rise until its average density equals the average density of the
surrounding air, thus achieving neutral buoyancy.
These concepts are explained in greater detail in any college level
physics textbook.
By, Christopher M. Seaman
Alcoa Technical Center
None of these examples consider compressing the air but I imagine for each cubic meter of air you can compress into a container, its overall weight will increase by ~3 lbs. Now you've got to figure out how much air creates a psi (Pressure).
What do you think?
..rickko..
Old Jun 17, 2005 | 01:04 PM
DJD Z06's Avatar
DJD Z06
Originally Posted by michach1
The air weighs the same whether its in the tire or in the box. Pressurized air doesn't affect the air density. Density of air is only 2.7 lb per cubic meter!
??? now I know why High School physics was so tough for me.....
Old Jun 17, 2005 | 01:21 PM
csexton's Avatar
csexton
Originally Posted by madeouttaglass
If you have 35 PSI in each tire that's an additional 140 Lbs that you're shipping.
Old Jun 17, 2005 | 01:30 PM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Is it Winter or summer air?
Old Jun 17, 2005 | 01:33 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
IB4TL
Old Jun 17, 2005 | 01:50 PM
Billy182's Avatar
Billy182
Explanation 1, 2 :
---> Best answer:
pV = nRT
p - pressure (Pa)
V - volume (m^3)
n - moles (mol)
T - temperature (K)
m = nM
where
m - mass (g)
volume.
physics textbook.
What do you think?
..rickko..
Yeah, what he said
Old Jun 17, 2005 | 01:56 PM
Biker Bob's Avatar
Biker Bob
will there be an altitude change from sending to delivery point
Old Jun 17, 2005 | 01:58 PM
sailohio's Avatar
sailohio
There are no stupid questions. Just stupid people that ask them.
Sorry. I just had to do that.
joghotrod's Avatar
joghotrod
I think somebody has too much time on their hands.
Old Jun 17, 2005 | 02:02 PM
Tom73's Avatar
Tom73
You sure. Maybe by taking the air out of the bottle you reduced the mass of the bottle assembly in relation to the surounding air and the bottle, due to less mass, is trying to float in the air.
I don't see how air in a bottle would have any effect on a set of scales. The air without the bottle does not have any effect. So why would adding the bottle make any difference. No if you put double the amount of air in the bottle, then you would increase the weight.
Old Jun 17, 2005 | 02:06 PM
  #33
flyzlow's Avatar
flyzlow
Send them C.O.D. and don't worry about it!
Old Jun 17, 2005 | 02:45 PM
  #34
vectorz's Avatar
vectorz
Well, apparently I must not be too stupid to ask, because obviously nobody's in agreement to whether it adds weight or not.
Old Jun 17, 2005 | 02:49 PM
  #35
vectorz's Avatar
vectorz
I opened up one of them, removed the air, and yes , it made a 5lb difference.
So, all of you that posted snobby condescending answers need to take your head out of your @ss and start apologizing. Man I swear *some* of you old folks are snobby, even when you're wrong.
Old Jun 17, 2005 | 03:18 PM
  #36
bmoranmd10's Avatar
bmoranmd10
Originally Posted by Eddyd
You could fill them with helium & it would be cheaper to ship
Old Jun 17, 2005 | 04:30 PM
  #37
ROCKnROLL's Avatar
ROCKnROLL
Veteran
There are no stupid questions.............
but you may get some stupid answers !!!
To This is a stupid question..
Old Jun 17, 2005 | 04:38 PM
  #38
CorvetteMick's Avatar
CorvetteMick
If it's the original factory air you may want to capture for future sale to an NCRS purist. It'll be worth it's weight in gold in 50 years.
Old Jun 17, 2005 | 04:49 PM
  #39
jawsski's Avatar
jawsski
Explanation 1, 2 :
---> Best answer:
pV = nRT
p - pressure (Pa)
V - volume (m^3)
n - moles (mol)
T - temperature (K)
m = nM
where
m - mass (g)
volume.
physics textbook.
What do you think?
..rickko..
Your hypothesis is incorrect. Air is not an ideal gas!
Old Jun 17, 2005 | 05:17 PM
  #40
Rag-Top Rick's Avatar
Rag-Top Rick
I favor "cheese wiz!"
