This is a stupid question..
Old Jun 17, 2005 | 12:00 AM
vectorz's Avatar
vectorz
Default This is a stupid question..
Do wheels weigh the same full of air, as they do without air?
I packaged up some rims w/ the tires mounted, and forgot to let the air out..
Should I open it and start over?
Old Jun 17, 2005 | 06:36 AM
ebubman's Avatar
ebubman
without any intent to provide a scientific or even correct response, it seems that air, being the liquid that it is, is affected by gravity and as such has weight. given the size of the average c5 tire & wheel, i tend to think that it does add weight & will cost you more to ship. now whether it's worth opening, purging, & repacking is a different issue. again, i'll defer to the pros to provide an accurate response. bub
Old Jun 17, 2005 | 06:58 AM
Yes, air does add weight, but not enough to worry about IMO. You could always take one wheel and do a before and after weighing of the wheel/tire to see what the difference is.
Old Jun 17, 2005 | 07:05 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
...are you sure!...did anyone consider the air used...
...or the barametric pressure at the time....how about the humidity level...
now I have to think about the altitudinal ramifications...
...does thin air really make a difference...
oh yea...
Old Jun 17, 2005 | 07:08 AM
Eddyd's Avatar
Eddyd
Default air
You could fill them with helium & it would be cheaper to ship
Old Jun 17, 2005 | 07:26 AM
Hot BluZ's Avatar
Hot BluZ
From: The problem with socialism is eventually the government runs out of other people's money
Think of the fun the people you're shipping to could have letting out the helium, they'd all sound like the munchkins from the Wizard of Oz.
Old Jun 17, 2005 | 07:31 AM
Billy182's Avatar
Billy182
Better yet, hydrogen is even lighter
Oops, that's right, I almost forgot.. that stuff blows up
UPS might not like that in their little brown trucks
Old Jun 17, 2005 | 07:45 AM
PaPaChoc's Avatar
PaPaChoc
You could put hydrogen in your tires as long as you keep the purity above 75%. Lower than that it will look just like that blimp! Boooommmmmmmmmmmmmmm!!!!!!!!!!!!
Old Jun 17, 2005 | 08:09 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
If you have 35 PSI in each tire that's an additional 140 Lbs that you're shipping.
Old Jun 17, 2005 | 08:11 AM
madeouttaglass
Senior Member
Cruise-In V Veteran
Wait, if each tire has a volume of maybe 200 cu. in. (just a wild guess) times 35 pounds per square INCH, that would be an additional 7000 lbs per tire!
ArmyVette's Avatar
ArmyVette
I love this whole thread!
Old Jun 17, 2005 | 08:13 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Thats what I was thinkin! lol
jeff
Old Jun 17, 2005 | 08:15 AM
WKMCD's Avatar
WKMCD
Since you have to pressurize air in your tire you are actually increasing the weight of the volume of air. I would recommend that you remove the air and use a non-compressable substance like water since you will not increase the weight through compression.
Old Jun 17, 2005 | 08:16 AM
madeouttaglass
Senior Member
Cruise-In V Veteran
Are they runflats? If not you have to have air in them to move them.
Old Jun 17, 2005 | 08:18 AM
madeouttaglass
Senior Member
Cruise-In V Veteran
Are you shipping air or ground? (or water?)
Old Jun 17, 2005 | 08:30 AM
ROADAPPLE's Avatar
ROADAPPLE
No! Air weighs alot. It is measured by the pound isn't it? You usually put 30 pounds in each tire so......
Old Jun 17, 2005 | 08:33 AM
vetdude's Avatar
vetdude
My wheels need air? OMG, better take it to the dealer - never put air in the wheels since I've owned it. What pressure do the wheels take? I know the tires take 30psi cold, but what about the wheels?
To This is a stupid question..
Old Jun 17, 2005 | 08:59 AM
michach1's Avatar
michach1
Edited (yes I am a geek!):
The air weighs the same whether its in the tire or in the box.
Atmospheric pressure is about 15 psi. Density of atmospheric air is 2.7 lb per cubic meter.
If you inflate to 30 psi cold, then you are effectively doubling the density to 5.4 lb per cubic meter.
If you didn't pressurize the tires, you could save about 2.7 lb per cubic meter of tire volume.
If you evacuated the tires of all air (vacuum), then you could save 5.4 lb per cubic meter.
Old Jun 17, 2005 | 09:00 AM
madeouttaglass
Senior Member
Cruise-In V Veteran
Non Z06s have runflat wheels.
Old Jun 17, 2005 | 09:11 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Fill the with Helium. The delivery guy will be able to dribble them like a basketball.
