Do C5s Need Engine Additives?
Old Jun 30, 2005 | 11:14 PM
FLL-Mike's Avatar
FLL-Mike
Default Do C5s Need Engine Additives?
Do our cars need injector cleaning additives or octane boosters???
I have 36K on the odometer.
Thanks,
Mike
Old Jun 30, 2005 | 11:15 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
The only time I've heard of anyone using them is when the gas guage acts up.
Old Jun 30, 2005 | 11:16 PM
hokievette03's Avatar
hokievette03
St. Jude Donor '05-'06
The gas guage thing is related to the sending unti which is IN the tank and is a mechanical device, i would highly recommend never putting those additives in...
Old Jun 30, 2005 | 11:28 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Techron usually cures the gas guage problem if yours is acting up, there have been MANY writeups on this. It's not for use ALL the time, just once in a while. Other than that, myself as well as many Forum members use Chevron or other better grades of gas that have the cleaners already added. Some folks that were having the gas guage problem who used some abc brand of gas switched to Chevron for a few tanks and it cleared up the problem.
Old Jul 1, 2005 | 04:44 AM
WWK888's Avatar
WWK888
That is the exact reason to use an additive such as techron. As stated above, it has helped many, many people with their fuel gauge problems.
Old Jul 1, 2005 | 05:49 AM
Patman's Avatar
Patman
Since the LS1 is prone to carbon buildup, I like to use a small dose of fuel system cleaner in every tankful. I use a product called Fuel Power, in a ratio of 1oz for every 4 or 5 gallons.
Old Jul 1, 2005 | 06:58 AM
A little cleaner every now and then is OK. I've never seen the need to use octane boosters in mine.
Old Jul 1, 2005 | 07:35 AM
FLL-Mike's Avatar
FLL-Mike
I dont know what you mean. How would the gas guage act up?
Old Jul 1, 2005 | 07:38 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
That's a fact.
Old Jul 1, 2005 | 07:42 AM
FLL-Mike's Avatar
FLL-Mike
I read a thread in the tech tip section where they clean out the carbon by adding GM top Engine cleaner in the pcv value. Do you think this is necessary at 36K??
Old Jul 1, 2005 | 07:47 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
We don't need no stinkin' additives...........(except a little Techron once and a while)
Old Jul 1, 2005 | 08:13 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Techron every now and then....good to go
Old Jul 1, 2005 | 09:35 AM
vettenuts's Avatar
vettenuts
Same here, recommended by Terry Dyson who does my oil analysis every year. I also use Lube Control in my oil which controls oxidation.
Old Jul 1, 2005 | 09:45 AM
ls1pwr1's Avatar
ls1pwr1
Old Jul 1, 2005 | 10:26 PM
FLL-Mike's Avatar
FLL-Mike
Thanks for your input!!!
Old Jul 1, 2005 | 10:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Been using 3 1/2oz per tankfull of RedLine's SI 1 Fuel System Cleaner for several years now with absolutely no harmful effects whatsoever. I use a full bottle (15oz) at oil change time every 9000 miles. BTW, I now have 107K miles on my DD. HTH
To Do C5s Need Engine Additives?
