Heat problem
Old Jul 3, 2005 | 02:07 AM
trejorob's Avatar
trejorob
Default Heat problem
Hey guys! I'm having this annoying heat coming from the center portion of the cockpit, I've notice the heat goes away when the AC is on, but otherwise it gets very hot inside, especially near my right leg. What should I check, or what should I do? I noticed the heat increased after installing my borla x pipe and mufflers. I have no headers and I have stock cats. (Kalifornia rules ) Anyhow, any suggestions would be greatly appreciated. Thanks
Old Jul 3, 2005 | 02:43 AM
Jims99frc's Avatar
Jims99frc
I just put my Chapstick in my left pocket , and deal with it . It is normal , but , annoying .
Old Jul 3, 2005 | 12:30 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
A ceramic coated tunnel plate (available in steel or aluminum, from a number of forum vendors) will help keep the heat out (as well as stiffen up the chassis). Unfortunately, you will have to remove/reinstall your newly installed X-pipe to get at it.
Old Jul 3, 2005 | 12:38 PM
pewterwest99's Avatar
pewterwest99
Mine goes in the ashtray because of this
Old Jul 3, 2005 | 02:08 PM
MagRedSkull's Avatar
MagRedSkull
It is normal. I've done 2 things that has almost completely eliminated the heat.
1. Tunnel brace helped.
2. Rejex insulation install from Crazy Cowboy (WWW.ExoticVette.COM) was the most effective.
Old Jul 3, 2005 | 02:59 PM
AU N EGL's Avatar
AU N EGL
Long Tube Ceramic Coated Headers will take the heat away from the foot wells in the cabin and the excess heat from the engine bay. Plus might add a pony or three
Old Jul 4, 2005 | 02:05 AM
trejorob's Avatar
trejorob
Thanks for all the input, the Rejex insulation sounds like the way to go and it's not that expensive. Thanks again brothers!
To Heat problem
