I complained to RotorPros about some wierd staining I was getting on my front rotors. Rich was nice enough to send me a new set FedEx in a matter of days. I clear coated the hats yesterday, but then I read the can. "Not for surfaces that will exceed 200 degrees."
How hot do the hats get?
200* ??? heck that is nothing. most ppl under normal braking rotor temps get 500-800*. On the track and under very hard braking it is not uncommon to see temps of greater then 1200-1400*
Look at this front rotor. the orange glow is the cast iron rotor hitting close to 13-1400*
After the rotors cools there will be a nice rainbow color of the rotor hat from hitting temps this high.
I have an infrared thermometer. After hard street driving, I have jumped out, to check the rotor surface temps, and they rarely got above 600. A lot of the heat dissipates to the fins, but the hats do see temps in the 300 to 500 range under normal daily driving.
Thanks! I'll remove what I have on there and go w/ a high temp paint.
... but then I read the can. "Not for surfaces that will exceed 200 degrees."
Sounds like you bought the wrong paint. When I went searching for Clearcoat at Pep Boys they had three types, Normal paint (what you bought), Plasti-Coat Engine enamel - good up to 500 degs., and a third type that needed a process like powdercoating to harden it (ie. must be put in 600 deg. oven).
I chose the 500 deg. paint. because I didn't have the proper oven to cure the third type. I've been driving for two months since painting them. The hats still look glossy.
Good luck!
..rickko..
I got the clear coat off with a paint remover and picked up some clear engine paint. Good for 600 degrees. Already done. All is good!
