Battery for c5?
Old Jul 9, 2005 | 04:28 PM
vettesrm's Avatar
vettesrm
Default Battery for c5?
I have a 2004 that I bought new one year ago this month. The battery is dying to the point where I have to jump it almost every morning.
So what's the best battery to get?
I live in Dallas so it's hot, and I hear the original battery that came with the late C5s are not good. Also, part of the problem is coming from a security/tracking system I bought when I took possession of the car. It's called MicroTrak. It's like LoJack but better. Here's a link
http://www.microtrakgps.com/index.php
The system is great, but apparently the company has had problems with the system draining the battery. They have new systems now that don't draw as much on the battery and they are gonna come out next week and replace the existing one.
But I really need a new battery today. I'll try and get them to reimburse me the cost of the new battery however.
Old Jul 9, 2005 | 04:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would be inclined to recommend an Optima Yellow top.
http://www.optimabatteries.com/publi...eep_cycle.html
It sounds like with your alarm system a deep cycle battery is more appropriate than a simple "starting" battery.
jmho......
Blue Lion's Avatar
Blue Lion
Most of us who have replaced our Delco batteries have Optima red tops. Mine works well so far. I paid $116 for mine including shipping/no tax. Go to Optima's website (do a Google search) for which model you need. I have the 34/78 which I believe is the more powerful red top. The yellow top is more powerful if you feel you need it.
Old Jul 9, 2005 | 04:37 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Old Jul 9, 2005 | 04:41 PM
vettesrm's Avatar
vettesrm
Thanks. Autozone carries the Optima, but is there a particular model number outside of being yellow or red?
Old Jul 9, 2005 | 04:51 PM
blacksedan87
In the Red Top, either the 75/35 (720 cold cranking amps) or the 34/78 (800 c.c.a.) will fit the C5. Not being real familiar with the Yellow Top, I think the battery series and sizes are the same.
Old Jul 9, 2005 | 04:56 PM
vettesrm's Avatar
vettesrm
Thanks for the info on the red top
Autozone says they don't show anything in there system to match a 2004 Corvette...odd.
So if I decide to go with the yellow top does anyone know the model number for the 2004?
Old Jul 9, 2005 | 05:24 PM
sundevilfan's Avatar
sundevilfan
Chevy covered my battery under the 36/36,000 warranty.
Old Jul 9, 2005 | 05:42 PM
GrayC5's Avatar
GrayC5
A few past threads you might want to take a look at:
http://forums.corvetteforum.com/show...l&forum_id=103
http://forums.corvetteforum.com/show...tal&forum_id=1
http://forums.corvetteforum.com/show...um_id=1&arch=1
Old Jul 9, 2005 | 05:44 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Red Top 75/35 works real well for me...
Old Jul 9, 2005 | 06:19 PM
Larry_Yerton's Avatar
Larry_Yerton
went to Pep Boys and just pulled it off the shelf works real well.
Old Jul 9, 2005 | 06:32 PM
blacksedan87
Following the link I put in my first post took me to the spec sheet for the yellow top batteries. It appears as though there is a model D34/78 (I assume the D stands for Deep Discharge). I know that many members here on the CF have the 34/78 Red Top. It appears as though the dimensions are the same.
The 34/78 is slightly larger than the 75/35, but it does fit in the space. From the specs, it looks like the 34/78 is 10"L x 6 7/8"W x 7 13/16"H.
The 75/35 is 9 5/16"L x 6 13/16"W x 7 5/8"H.
These sizes are consistent with both the Red Top and the Yellow.
The D34/78 (Yellow) is 750cca, and the 75/25 Yellow is 650 cca.
The 34/78 (Red) 800 cca and the 75/35 (Red) is 720 cca.
As I indicated before, these are the two sizes and models that will fit the C5.......
Old Jul 9, 2005 | 07:46 PM
stevzc5's Avatar
stevzc5
Red Top 34/78 here. No problems so far.
Old Jul 9, 2005 | 08:30 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I bought another Delco battery, the optima battery just doesn't look right in the engine comparment.
I guess I just have to be different.
Old Jul 9, 2005 | 08:45 PM
Dave68's Avatar
Dave68
Best for cold weather performance:
1. ProStart (Pep Boys), series 65: $60 CR Best buy
2. Interstate: $75
3. Advance Autocraft, series 75: $55CR best buy
4. Advance Autocraft, series 24: $50
Advance Autocraft, series 34/78: $75 CR Best buy
"All of these batteries deliver a good blend of life and cold-starting power in their group size."
Best for warm weather performance:
2. Advance Autocraft, series 75: $55 CR Best buy
3. Advance Autocraft, series 24: $50
4. Advance Autocraft, series 34/758 $75 CR Best buy
"The ProStart (1) and Advance (series 24 and 34/78) excelled in our life tests."
If reserve power matters most:
2. Interstate, series 75: $75
4. Advance Autocraft, series 34/78 North: $75 CR Best buy
5. Diehard, series 34/78: $90
"All excelled in reserve capacity. The Interstate and Diehard had superior CCA performance."
I'm guessing that the Optima was not included because of its higher-than-normal price range, which tends to restrict its sales to those who are extremely concerned about leaks. That being said, I've been driving since 1974 and have never had a leaking battery, so I guess we can compare buying an Optima to buying runflats?
Old Jul 9, 2005 | 08:51 PM
Yoggi's Avatar
Yoggi
Yep thats the way to go.
Old Jul 9, 2005 | 10:14 PM
ttaylor's Avatar
ttaylor
Warranty, it's between the bumpers, they coverd mine.
To Battery for c5?
Old Jul 10, 2005 | 12:09 AM
Vettman 1's Avatar
Vettman 1
Old Jul 10, 2005 | 12:18 AM
mixermike's Avatar
mixermike
Old Jul 10, 2005 | 12:44 AM
SLPRC5's Avatar
SLPRC5
Good luck...
