Stinger or Blackwing...
Old Jul 31, 2005 | 11:06 PM
loudsam's Avatar
loudsam
I like the Blackwing. I've got 10,000 worry-free miles on it, through lots and lots of rain, with no problems.
Old Jul 31, 2005 | 11:28 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Originally Posted by madman7
Will I be able to notice a difference in power tommorow when I install this?*halltech stinger?
You should notice some gain, and you will hear more air sucking noise into the intake...
Old Jul 31, 2005 | 11:43 PM
I have the Blackwing on mine. Not sure how much performance increase it gives, but I noticed better throttle response right off. I've never had any problems with warranty issues on mine.
Old Jul 31, 2005 | 11:47 PM
Dave68's Avatar
Dave68
Give it some time so that your C5's computer can adjust to the higher flow of air into the throttlebody and intake manifold. See Jim's comments below:
"Allow 25 miles of driving to provide relearn time for the PCM> All fuel trims will eventually retrim to 14.7:1 except WOT. That will be leaner, but still well within the power range and will likely provide 5 to 6% more torque and horsepower throughout the rev band.
Please understand that new air will not cause your car to run lean. The factory air fuel ratio is 12.3:1 for Wide Open Throttle, which is way too fat for max power. Our intake does not need programming to operate properly, but will see added benefits from a good LS1 Edit program.
info@CorvetteC5.com
Jim Hall"
For installation instructions, see:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
You WILL notice a difference, particularly at higher revs.
Old Aug 1, 2005 | 12:23 AM
SLPRC5's Avatar
SLPRC5
Default Blackwing
I installed the Blackwing this weekend and took 160 mile run. I could fell the power of rapid response (at 2000 RPM) over the K&N filter I had attached to my BBK cold air induction. As others said you can hear the high suction from the Blackwing. I hear it more because I'm running hi-flo cats, X-pipe and ZO6 Ti catback exhaust.
As its been said the LS1 performs much better with a high flow intake of air and a low restriction exhaust system. With all said I recommend going with the Blackwing again it is GM approved.
Old Aug 1, 2005 | 12:41 AM
vetterlatethannever's Avatar
vetterlatethannever
I have the stinger and like it alot, great bang for the buck IMO!!
