Tire problems (possibly store done)
Old Aug 9, 2005 | 10:22 PM
WrEcKeD1101's Avatar
WrEcKeD1101
Default Tire problems (possibly store done)
Edit: New 2nd pic which shows the rubber missing down to the belts....
Ok, here's the problem. My driver front tire has a slow leak and when I want to drive the car, I have to air the tire up (not totally flat, but loses ~ 6-8lbs). I think the problem may have started when I had the wheel apart for powdercoating. They are the 3pc CCW classic wheel. I believe that the leak is around the rivots/screws, so I monkey'd with them for a few trys. I put silicone around the screws before tightening.
No dice on that. Here's where the problem comes in. I took the wheel only to the local tire store (Monday) here to have them remove the tire from the wheel so I can apply some silicone on the inner rim where the barrel comes together (I did that night). My wife brought the wheel back to the store after 24hrs for the silicone to cure. They mounted the tire and then noticed something that wasn't right and explained to her about the problem.
Here are some pics that show the problem:
I don't know what to think. Is this tire failure and should it be covered under warranty? Did the tech do this when taking off the tire? Why wouldn't they have said anything when the tire was taken off?
What do you guys think?
Sorry for some of the usless info....
Old Aug 9, 2005 | 10:27 PM
VLVETTE's Avatar
VLVETTE
Because they probably did it putting it on and no offence they were dealing with a woman an figured they coud get away with that
That doesn't look like tire failure. Looks like tire man failure. I would take it back and scream bloody murder. If you would have done that your rim would show rash. Go get-em
Old Aug 9, 2005 | 10:32 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Sure looks like mount ,dismount damage to me....
Old Aug 9, 2005 | 10:37 PM
Armadillo's Avatar
Armadillo
The close-up is out of focus so it's nearly impossible to see what you've got there. Can't tell if it's a chunk out or excess material. So what was the tire store guy's explanation of what it is and how it happened. I assume it didn't leak before being taken off for the powder coat job? Where did you get the tire and how long have you had it? It looks like a mfg. defect from what I can see.
Old Aug 9, 2005 | 10:39 PM
gairno's Avatar
gairno
I could not more.
Old Aug 9, 2005 | 10:54 PM
WrEcKeD1101
I didn't realize how crappy that 2nd pic was. That is a chunck missing down to the belts.
When my wife went to pick up the tire, the tech pointed out to her and said that it wasn't good and I need to replace the tire.....of course.
I don't think that I have ever seen a tire failure in that location. The tire is fairly new and has ~7-8k miles on them. I'll be calling them in the morning.
The tires did not leak before I had the centers off, but that was the only thing off. I let all of the air out of the tire, removed the bolts and the center comes out. The tires were never off during this process.
Old Aug 9, 2005 | 10:56 PM
WrEcKeD1101
That is the inside of the rim. I did not see rash anywhere on the rim. Let me see if I can get better pics.
Old Aug 9, 2005 | 11:02 PM
WrEcKeD1101
better 2nd pic added
Old Aug 9, 2005 | 11:22 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
good luck and let us know how you make out.
Old Aug 10, 2005 | 12:19 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Guys, that is a chunk bitten out of the tire with a tire machine. I'm no tire man but I've changed alot of tires in my day.. mostly by hand but we did alot of them in the old days... This was pinched with the machine and it tore a chunk out. That's no tire defect from a Mfg. problem... (In My Opinion)
What you might do is take the thing to a DIFFERENT tire store and ask them about it first.. see what they tell you about it. You don't have to tell them which store did this or anything and I wouldn't be a jerk to anyone about it but simply ask the different tire store what their thoughts are... Do you know of someone who is a little more reputable??
Then take it back to the original place and speak to them about it. Don't leave without getting them to make it right with you... If you can't fix it right then and there, get it in writing!!
All IMHO... OK?? That was crappy of them to ever let your wife take it away from their store.. SHAME ON THEM!!!
Old Aug 10, 2005 | 08:07 AM
andy60's Avatar
andy60
I also have changed many, many tires by hand and using the old coats machines. This is damage is from the tire mount, no doubt about it.
I hope you get it fixed. If you run it as is you could have problems with it in the future.
Old Aug 10, 2005 | 12:05 PM
WrEcKeD1101
I will not be able to take it to another tire shop for a 2nd opinion since I get home around 7PM. Everything is closed by then.
I think I will try to have a civil conversation with the store manager.
Old Aug 10, 2005 | 12:54 PM
I'd have to agree that it looks like damage done by a tire machine. Looks like a talk with the service manager is in order. Good luck.
Old Aug 10, 2005 | 01:02 PM
DeeGee's Avatar
DeeGee
Name and shame so we can avoid them. Sounds like bad practice to me.
Hope you get some satisfaction
Old Aug 10, 2005 | 02:40 PM
WrEcKeD1101
I'll let you guys know how it goes when I talk to the manager. Until then, I'll leave the shop name out...but it is a pretty big one.
Old Aug 10, 2005 | 02:43 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
That's unreal scottie........ If I were you, I'd get back on the phone with "Discount Tires" and really lay into them!
Old Aug 10, 2005 | 02:46 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
You could try going back and showing them. Did you get the tire from them? If so they could swap it out and easily claim it through their distributor.
Good luck.
Micah
To Tire problems (possibly store done)
Old Aug 10, 2005 | 02:52 PM
LB04CE's Avatar
LB04CE
Hope you det it worked out with them, because they did it...........
Old Aug 10, 2005 | 02:58 PM
pewterwest99's Avatar
pewterwest99
Hopefully the manager will make it right for you.
I had a Very well known chevy dealership in Houston do my alignment wrong and it ruined one of my front tires. When we looked at the spec sheet( they brought it up on the computer when we came in looking for a replacement tire) it showed that they had screwed up on aligning (2) of the tires. It was proof on paper and I still had to fight with 3 different managers to get them to replace the tire when it was clearly thier fault. Needless to say I will NEVER be returning there and I will advise everyone of the horrible customer service that I received from
MAK HAIK CHEVY ON I-10
My advice... Stay on their case about it and don't let up. If it is their fault then they need to pay for it.
Old Aug 10, 2005 | 06:17 PM
WrEcKeD1101
Going to see the manager tomorrow. I'll keep you informed!
