CAM Question?????
Old Aug 13, 2005 | 11:49 PM
glind46677's Avatar
glind46677
Default CAM Question?????
I have a 2004 Automatic Vert. It has 342 gears, kooks headers, vararam, B&B exhaust and X pipe. Been thinking about a cam. Dont race the car street only. Just looking for a little more punch around town. Any suggestionss???
Old Aug 14, 2005 | 12:12 AM
not08crmanymore's Avatar
not08crmanymore
Default cam
ecs put in a g5x3 cam on my 01 6spd.kooks too.a little tune and now i have 392 h.p.358 torque.you can go there with a cam,or get a z06 cam.
Old Aug 14, 2005 | 02:33 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Take a look at Futral Motorsports they have some good cams that make great low end power.
Old Aug 14, 2005 | 09:39 AM
Dark-Knight's Avatar
Dark-Knight
Many cams typically bring on power at the upper rpms, some bring the power on lower in the rpm range. Sounds like the latter may be what you're looking for. The cam noted im sig kicks in at the lower rpms, @ about 3,000.
By the way, if your doing a cam suggest you consider doing a under drive pully (to liberate some ponies) at the same time to save labor or labor costs.
Hope your find what you're looking for!
Old Aug 14, 2005 | 09:44 AM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
DRKNGHT cam is an around good daily driver cam. If you dont plan on doing any racing and just want alitle more kick when you hit the gas then go with a 228/228 581/581 114lsa
Good Luck
To CAM Question?????
