Dead battery this morning
Yesterday when I came home, it was fine. Indicated voltage was around 14, so it's charging OK best I can tell. I suppose it just had a quick death.
Is the Optima Redtop still the battery of choice. Anybody know what size to get ... I don't have my manual handy. And ... what can I expect to have gone wrong with the computer, radio, etc., from the power loss?
Thanks.
Replaced it with an Optima Red Top.
Worth checking you didn't leave the panel lights on overnight. I made that mistake recently.
You may be interested in this thread. Its a common problem:
http://forums.corvetteforum.com/show...0&forum_id=103
The last thing you should do is spend $100+ for something you may not need. I would charge the battery and then have it and the charging system checked.
They guy checked the battery w/ a volt meter and it was only reading 2 volts. So they took it and gave me a new one... Glad mine just died in front of the service dept...
Last night, my radio wouldn't work so I figured I would have to go through the unlock procedure ... and I bought the car used and have no idea what the code is. But overnight the computer must've done some thinking, because this morning the radio was working fine.
And a note ... installing a battery in a C5 when it's hot and humid is no fun!
There's not much room to screw the side mount cables in, and it's even worse when you're sweating all over your glasses and can't see.
But I got it in ... and when I was locking it down, the socket fell off the end ... it's somewhere in the wheel well even as I type. Saturday chores will include removing the front right wheel, and then the wheel well liner, and trying to find the socket and short extension, unless it fell out somewhere.
