Can't physically get to #7 spark plug
Old Aug 20, 2005 | 10:05 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by shurite44
I had a socket extension with two elbows. Not sure of the technical name of the tool. I just worked it over the plug then used the ratchet to loosen, after it was loose I turned the extension by hand, put a little side pressure on the plug and pulled it out with the socket.
The elbow is the key
