This is related to that long rant from the guy (Yesterday) that just purchased his vette and was worried about how so many things were going to go wrong... See he told you so!! All you have to do is blow air on the tire and it has problems!!! SHEEESH!!
Probably was the Magnetic relay of the Centerfugic copper coil in the leaf blower throwing off the sensors? Was it a gas or electric blower?? Most probably the electric since it always seems to do that to the sensors. Buy a gas blower, it wont happen then
Those chrome reverse muffler bearings will do it every time. You need to install the stainless steel muff bearings. You can get from any vendor for almost nothing.
Are you serious.... For a moment I was lost, and I was like...WTH...?!!!! Now, either youre so ignorant that you should trade your Vette for a VW, or you must be joking...
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
Originally Posted by chocoholic
Well, it depends on which version of the run-flats that you have on your car.
If you have the run flats that never need filling with air (I think this was discussed last week), then you can safely ignore this message.
If, on the other hand, you have the more common version then you probably didn't dry your car in a proper star pattern. Not drying the car in the correct fashion tends to cause a build-up of air at one corner and a loss at the other. You can correct this by washing and redrying the car but, this time, weighting your time so that the average over the two washes is the same.
Alternatively, you could put some air in your LR tyre and resort to the old-fashioned trick of checking your tyre pressures on a regular basis.
I think you're on to something here! I have also heard that improper torquing of the tail lights can cause a problem and throw the whole car out of balance. Another suspect area is over-tightened seatbelt tensioners. This is often first noticed by uptight drivers.
This is why I check out the forum at least once a day...where else are you going to find this kind of information!?!
