Used the leaf blower trick...problem
Old Aug 24, 2005 | 08:01 PM
eightyvette's Avatar
eightyvette
I read that a lot of members use a leaf blower whn drying their cars.
I did tonight, and it seemed to work great. When I started up, the digital readout read - "low presssure LR"
Any thoughts, suggestions,??
Old Aug 24, 2005 | 08:03 PM
DngrZne's Avatar
DngrZne
Let me just ask a dumb question, just to make sure we aren't missing something easy...did you check the tire pressure and make sure that it wasn't in fact low?
Old Aug 24, 2005 | 08:04 PM
Patches's Avatar
Patches
Check the LR tire pressure manually and see what it reads. Could be a TPS glitch as they are prone to occassionally dropping out. If the sensor is reading incorrectly, it will probably resynch the next time you take it for a spin.
Old Aug 24, 2005 | 08:22 PM
eightyvette
It was fine an hour before when I backed it out of the garage.
Old Aug 24, 2005 | 09:59 PM
The Shooter's Avatar
The Shooter
The leaf blower sucked the air right out of the tire..??......or...you got the blower too close to the tire and blew the air right out of it.. just a thought..............................
Old Aug 24, 2005 | 10:39 PM
rws.1's Avatar
rws.1
or the leaf blower blew a piece of nano-particulate clay thru the side wall and created a slow leak ?
Old Aug 24, 2005 | 10:41 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
just a coincidence?
Old Aug 24, 2005 | 10:45 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
That happens every time I dry my car with the leaf blower
Just a kowinkidink...
Peace
Willfulone
Old Aug 24, 2005 | 10:52 PM
b98's Avatar
b98
Old Aug 24, 2005 | 11:04 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Originally Posted by mrm1149
just a coincidence?
Old Aug 24, 2005 | 11:14 PM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
This may be too obvious, but how long was the vette sitting before you got this reading? You do know that the tires need to be rotating for a distance before the tps will get an accurate reading dont you?
Old Aug 24, 2005 | 11:18 PM
GDP's Avatar
GDP
That sounds dangerous. I'd get it towed to your local Corvette mechanic.
Old Aug 24, 2005 | 11:27 PM
zinbaad's Avatar
zinbaad
Probably was the Magnetic relay of the Centerfugic copper coil in the leaf blower throwing off the sensors? Was it a gas or electric blower?? Most probably the electric since it always seems to do that to the sensors. Buy a gas blower, it wont happen then
Old Aug 24, 2005 | 11:29 PM
Has to be a coincidence. Perhaps the tire is low.
Old Aug 24, 2005 | 11:41 PM
jrose7004's Avatar
jrose7004
just a coincidence?
That's what I'd think!
Old Aug 24, 2005 | 11:44 PM
mjtihen's Avatar
mjtihen
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Maybe try a hair dryer instead
Old Aug 25, 2005 | 12:05 AM
exile's Avatar
exile
Are you drunk?
To Used the leaf blower trick...problem
Old Aug 25, 2005 | 12:07 AM
TOPGUN9's Avatar
TOPGUN9
This is too funny!!
Old Aug 25, 2005 | 12:08 AM
NSTG8R's Avatar
NSTG8R
hrmm ..
now i understand why there is a corvette tax.
Old Aug 25, 2005 | 12:10 AM
chocoholic's Avatar
chocoholic
Well, it depends on which version of the run-flats that you have on your car.
If you have the run flats that never need filling with air (I think this was discussed last week), then you can safely ignore this message.
If, on the other hand, you have the more common version then you probably didn't dry your car in a proper star pattern. Not drying the car in the correct fashion tends to cause a build-up of air at one corner and a loss at the other. You can correct this by washing and redrying the car but, this time, weighting your time so that the average over the two washes is the same.
Alternatively, you could put some air in your LR tyre and resort to the old-fashioned trick of checking your tyre pressures on a regular basis.
