Used the leaf blower trick...problem
Old Aug 25, 2005 | 06:21 PM
  #41
TOPGUN9's Avatar
TOPGUN9
Originally Posted by JCGRCYA
I hope he is joking. If not, I hope he can take a joke. You guys are messed up. What happened to "there is no such thing as a dumb question"?
We lied!!
Old Aug 25, 2005 | 06:34 PM
  #42
Prism911's Avatar
Prism911
Whoever said that was wrong.
Old Aug 25, 2005 | 06:41 PM
  #43
I X L R 8's Avatar
I X L R 8
Originally Posted by eightyvette
I read that a lot of members use a leaf blower whn drying their cars.
I did tonight, and it seemed to work great. When I started up, the digital readout read - "low presssure LR"
Any thoughts, suggestions,??
It's abundantly clear to me that the Leaf Blower has caused this malfunction and it has nothing at all to do with the tire sensor.
Since the advent of the leaf blower, cars throughout the nation have had tires mysteriously lose air pressure any time one is in operation around them.
Which is why when I use my leaf blower, I wrap all four of my tires in saran wrap to keep the contaminated air away from them.
Old Aug 25, 2005 | 06:49 PM
  #44
The Shooter's Avatar
The Shooter
Originally Posted by jedicowboy
I think there is a problem with the Gyroscopic Actuator. Sell the car immediately.
It's the Flux Capacitator not the Gyroscopic Actuator. This I know B/C the same thing happend to me
Old Aug 25, 2005 | 06:53 PM
  #45
RonnieM's Avatar
RonnieM
that's what extended warranty is for. You do have it? Don't ya?
Old Aug 25, 2005 | 07:29 PM
  #46
Fixed Roof Coupe's Avatar
Fixed Roof Coupe
Originally Posted by chocoholic
Well, it depends on which version of the run-flats that you have on your car.
If you have the run flats that never need filling with air (I think this was discussed last week), then you can safely ignore this message.
If, on the other hand, you have the more common version then you probably didn't dry your car in a proper star pattern. Not drying the car in the correct fashion tends to cause a build-up of air at one corner and a loss at the other. You can correct this by washing and redrying the car but, this time, weighting your time so that the average over the two washes is the same.
Alternatively, you could put some air in your LR tyre and resort to the old-fashioned trick of checking your tyre pressures on a regular basis.
Plenty of hot air to go around!
Old Aug 25, 2005 | 07:51 PM
  #47
countslav's Avatar
countslav
I'm on the floor laughing my azz off....This is too funny...You guy's are the greatest...
Old Aug 25, 2005 | 08:01 PM
  #48
Poptops's Avatar
Poptops
What's the phone number for the support group for the air pressure challenged? Just kidding ... ala Saturnight live: "PUMP YOU UP"!
Old Aug 25, 2005 | 09:50 PM
  #49
tsts's Avatar
tsts
I think this question should be submitted to Moulder & Scully . . .
Old Aug 25, 2005 | 10:40 PM
  #50
Richie Carbone's Avatar
Richie Carbone
Are you didn't blow some of the blinker fluid out of the housing causing the TPS to have a false reading?
You might also want to check your piston return springs and muffler bearings while you're at it.
Old Aug 26, 2005 | 12:28 AM
  #51
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Muffler bearings... I haven't heard of those since just after high school... That was a looonnnggggg time ago!!
We used to always say that!!
Old Aug 26, 2005 | 11:21 AM
  #52
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
I think this should be over in OT
