Shell V-Power
Old Aug 31, 2005 | 09:33 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Shell has one of the highest sulphur contents on the market. I avoid it like the plague.
GM actually has a bulletin out recommending Chevron and BP as the only makers keeping their additives within spec. Other automakers are also recommending these two per the same research. I use BP (so does the factory at Bowling Green) and add Techron when I can (techron is already in chevron gas).
Old Aug 31, 2005 | 09:48 AM
Z0SLIK's Avatar
Z0SLIK
Originally Posted by b98
ok in mine
Yep!! Me too!!
Old Aug 31, 2005 | 11:25 AM
cuspid's Avatar
cuspid
Noticed my mileage has decreased dramatically on my 3 vehicles since trying v-power.
Old Aug 31, 2005 | 11:52 AM
CORVETTE CRAZY 2's Avatar
CORVETTE CRAZY 2
I only get about 90 miles with 20 bucks at 2.91 a gallon
but when i use others at same price exxon mobile amoco they all tend
to give me 10 or 15 miles more. maybe v power has a stronger octane
that cause's it to burn faster
Old Aug 31, 2005 | 12:36 PM
WEF's 95's Avatar
WEF's 95
Do you have a link to that info?
Old Sep 1, 2005 | 05:43 AM
WEF's 95's Avatar
WEF's 95
Please post a link to this bulletin.
Old Sep 1, 2005 | 08:39 AM
BQuicksilver
It's on my eSi CD, which I don't have installed right now. If anyone has the updated electronic service manual for our cars, it was an addition in the past few years. Sory I can't be more specific, it takes quite a while to reinstall all 7 CD's. GM did some research with toyota and one other maker if I recall, and came to conclude these gasoline makers were the only ones whose additive profiles were appropriate for long term engine safety. It was basicly a plea to other oil companies to follow suit.
Old Sep 1, 2005 | 08:44 AM
javamon's Avatar
javamon
By the sound of this morning's news, I'll be lucky to find gas at the local Piggly Wiggly! Gas stations are drying-up here!
Old Sep 1, 2005 | 09:02 AM
CRZYCDN's Avatar
CRZYCDN
I've been using Sunoco 93 in the 95 Grand Am and the 97 Prelude, 02 Vette, they all run great on it. I have always used Sunoco and the mechanic is always impressed with the inside of the engine (tune up time).
I get 29-32 on the highway in the yellow rocket.
CRZY CDN (not really crazy just drive that way)
Old Sep 1, 2005 | 05:06 PM
cuspid's Avatar
cuspid
Alcohol in v-power equals less energy/ worse mileage. There was a thread on toptier gas that says it is 10% alcohol.
Old Sep 1, 2005 | 05:40 PM
WEF's 95's Avatar
WEF's 95
From the Toptier website:
1.3.1.2 Base Fuel. The base fuel shall conform to ASTM D 4814 and shall contain commercial fuel grade ethanol conforming to ASTM D 4806. All gasoline blend stocks used to formulate the base fuel shall be representative of normal U.S. refinery operations and shall be derived from conversion units downstream of distillation. Butanes and pentanes are allowed for vapor pressure adjustment. The use of chemical streams is prohibited. The base fuel shall have the following specific properties after the addition of ethanol:
Contain enough denatured ethanol such that the actual ethanol content is no less than 8.0 and no more than 10.0 volume percent.
It looks like all top tier fuels have alcohol??? Maybe I read it wrong.
After my gas gauge crapped out, probably from Wawa gas, I switched to Shell and the gauge is good but mileage did drop by as much as 2 mpg. I'm going with Texaco with Techron and hope for better mileage.
Old Sep 1, 2005 | 05:46 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
Regarding BP gas, my Amaco gas stations turned into BP stations around here in NY.. is this a Nationwide thing?
thanks
Old Sep 1, 2005 | 08:34 PM
  #33
javamon's Avatar
javamon
thanks
Same thing here in the Fla panhandle
Old Sep 1, 2005 | 08:50 PM
  #34
slverc5's Avatar
slverc5
I think I'm switching to Mobil, I mean it's just make sense since the oil my dealer uses is Mobil 1, why not use the same gas brand as my engine oil. I know that there mgith not be any relation, but I'm only getting about 15-16 mpg's whether I drive the car hard or not. Just does not make sense. I used to use Shell on my CRV and Durango and I also get crappy mpg numbers. Since I switch to BP Amoco, my mpg numbers went up and only about 1 mpg off the rated mpg use. BTW, don't get confuse, I'm using BP Amoco for my other 2 cars, I'm just switching to Mobil for my Vette.
Old Sep 1, 2005 | 10:01 PM
  #35
jjjflex's Avatar
jjjflex
V-power at every fill up. But, would be open to experiment.
Old Sep 1, 2005 | 10:19 PM
  #36
28tudor's Avatar
28tudor
Default Interesting
interesting info & input. Funny how our cars have, apparently, sticking gas guages. Great cars, but Hey, It's only a Chevy, a neat Chevy, but.. They have got to have gas guages figured out by now. My Ford Model A (hence the name 28 Tudor) runs great on any old thing that smells stronger than beer! and the gas guage works just like a toilet float with a mechanical pointer, Hillarious. but foolproof.
Old Sep 1, 2005 | 10:39 PM
  #37
Chris.Shea's Avatar
Chris.Shea
i have been using chevron only since i started driving. not too long ago shell had a big problem in sough florida and everyones gas guages went bad when there was too much sulfur in the fuel. the car seems to like chevron the best but if i ever get stuck in a tight spot i buy the shell hell i pay the extra cent a gallon to drive across the street to get gas at the "new" station when another older chevron station is across the street.
Old Sep 13, 2005 | 09:27 PM
  #38
cuspid's Avatar
cuspid
I switched back from shell and my mileage is up 2 mpg, more than 10% increase.
Old Sep 13, 2005 | 10:41 PM
  #39
BQuicksilver
Suphur = Sticking gas gauges. Shell = High Sulphur
BP, Chevron = Lowest Sulphur (Chevron also has Techron, which is about the only additive I like)
