Repair or Replace
Old Sep 3, 2005 | 06:34 PM
JJG01Silver's Avatar
JJG01Silver
Default Repair or Replace
Hit some road debris on the expressway. Ripped off the right air dam, ruined the tire, cracked the fender and crushed the rocker panel. Been to several body shops. Two recommend repairing so they can blend in the paint without having to go into the hood area and the rear quarter panel. Two were for replacing the fender and rocker panel (big job - and much more expensive) I'm leaning to repair but I would love some thoughts. Thanks.
Old Sep 3, 2005 | 06:43 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Geez, sorry to see that. I'd have the parts replaced.
Good luck!
jeff
Old Sep 3, 2005 | 07:11 PM
DeeGee's Avatar
DeeGee
I feel your pain.
I'd bite the bullet and go for the full repair. Best of luck
Old Sep 3, 2005 | 11:15 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Ouch! Sorry to see that. Another vote for replacement here.
Old Sep 3, 2005 | 11:24 PM
diyguy's Avatar
diyguy
REPLACE parts.
Someone is throwing about paint not matching.. **GEESH** it's white! No metallic, no nothin. Should be a really eash fix. Presume insurance to cover it?
Old Sep 4, 2005 | 01:05 AM
VLVETTE's Avatar
VLVETTE
Originally Posted by diyguy
REPLACE parts.
I think his car is silver. I don't know how much of an issue paint matching would be. If your insurance would cover the replacement option I think I would lean toward it anyway.
Old Sep 4, 2005 | 02:18 AM
diyguy's Avatar
diyguy
Could be silver - Bad monitor
In either case....REPLACE the parts
Old Sep 4, 2005 | 02:31 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I have to agree to - not sure how well this Sheet Molded Composite takes to repairing. Fenders are easy off and easy on. The rocker panel is a little more difficult, but I have no doubts that a competent professional body shop with familiarity of Corvettes can do the job to your satisfaction. Also - paint match has become a science and much less experimentation.
If your insurance company will agree to it - have the parts replaced, you'll be much happier with the outcome.
Sorry for your mishap. Good luck with the repairs.
Old Sep 4, 2005 | 05:19 AM
sjc*2's Avatar
sjc*2
One of the features or the vette is the screw on panels. Proper body shop should replace all your panels. Also they should be painted off the car. The Door panel can also be removed for blending if required. Don't repair them.
Old Sep 4, 2005 | 05:21 AM
TruUndrtkr's Avatar
TruUndrtkr
That's hard to look at..
Old Sep 4, 2005 | 08:14 AM
Pureenergy's Avatar
Pureenergy
Old Sep 4, 2005 | 08:24 AM
ebubman's Avatar
ebubman
wow. saw the photo & thought "my aching *ss" . i tend to think either option would be fine if performed by a competent body shop. it's hardly a surprise that an insurance company would prefer the lower cost option. consumers tend to argue on emotion rather than reality, particularly given how much we love our vettes. my bro in law is an adjuster with a major auto insurance carrier (which btw is a real pita job). i think if you reasonably & respectfully (not arrogantly) argue, you can hit a middle ground. good luck. bub
Old Sep 4, 2005 | 09:54 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I'd have them replace the front fender since it's an easy bolt on/bolt off part. The rocker panel is a whole different story though. That part has to be peeled and chiseled off since it's glued on in several places.
In my opinion replacing the rocker will do far more damage to the car than simply repairing it.
Tom
Old Sep 4, 2005 | 10:08 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i can help you out on this, i'm assuming this is an '01 quicksilver? there's 3 diff silvers for c5's, 97-00,01-03 quicksilver, and 04 machine silver; if you can find the parts i'll help you replace them, i had 6spd98 drive up from queens a few weeks ago, depending how far off the verrazano you are i'm about 2 hours away
Old Sep 4, 2005 | 10:53 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
I'm slow to respond here but I was shocked when it was called "White"... I thought, "Man do I need an eye exam!"
I'd ask the body shops that looked at it, (Yes ALL four) as to why they chose to repair or replace the panels.
I'd think that REPLACE is the only option but Tom made a good point...If it's more damaging to remove the rocker.. well...
Look deeper into it with professionals giving the reasons why or why not... I'd guess few of us has done it and we are indeed using our emotions for the reasons why...
I agree that the paint match is a fishy story... no matter what, you're going to have to match the paint!! Hmmmmm....
This sort of thing requires some indepth work as to what kind of work these shops can do as well....
Yup, **** as hell here...
Good LUCK!!
Old Sep 4, 2005 | 11:11 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I agree
Old Sep 4, 2005 | 12:09 PM
JJG01Silver
I want to thank everyone for their thoughts and particulary single out Connecticut for his gracious offer. My original concern was for removal and replacement of the rocker which does require a significant "tear down" and reassembly of the vehicle (which comes directly from a tech a Chevy) and I was a little (a lot) squeamish about having even a professional tear down the vehicle. Cost was not the consideration because with my deductible, my out-of-pocket would be the same with either repair or replace - Repair I pay for myself including the tire and alignment which comes to the amount of my deductible.
I was originally leaning toward the repair. Given your comments I am now learning toward replace the fender, repair the rocker.
Thanks again for your thoughts and if please keep them coming.
To Repair or Replace
Old Sep 4, 2005 | 01:15 PM
jrose7004's Avatar
jrose7004
I would want the parts replaced if it were mine!
Old Sep 4, 2005 | 01:36 PM
AGMS's Avatar
AGMS
Old Sep 4, 2005 | 03:09 PM
Patches's Avatar
Patches
I would never be satisfied with a repair job on that kind of damage. A good shop can replace that rocker panel with no problems because they know what they're doing. Insist on new, original GM replacemnet parts or you may regret it down the line.
