Can low octane gas cause check engine light?
Old Sep 3, 2005 | 10:35 PM
Ubenripped's Avatar
Ubenripped
Default Can low octane gas cause check engine light?
Yesterday I had to get gas. Seems to be near impossible to find around here right now. I went to 6 gas stations before finding one that even had gas left but they only had 87 octane. I always use at least 91 octane but it was either that or run out of gas. This evening my check engine light came on. Could running 87 octane cause this or is it just coincidence? All of my temps and gauges seem to be within normal operating parameters and I can't hear anything that sounds different. I'm getting it scanned in the morning to find out what the code is but between it being the weekend, a holiday, and a major natural disaster the dealer MAY be opened Tuesday at earliest.
Old Sep 3, 2005 | 11:28 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Need to read the code, no sense in speculation
Old Sep 4, 2005 | 12:18 AM
not08crmanymore's Avatar
not08crmanymore
Default light
if the car is RUNNING WELL,even though the ck.engine light is on,then you should be fine till tuesday.Bad gas can make your light come on.seen it many times.try a bottle or two of dry gas,ck your gas cap,and see if it goes out on it's own after that,in a day or two.it needs to cycle out.
Old Sep 4, 2005 | 12:25 AM
GettReal's Avatar
GettReal
I remember testing it out....I put regular in my car and within an hour the check engine light came on... ran the gas out and put premium back in...was fine
Old Sep 4, 2005 | 12:28 AM
StevieB's Avatar
StevieB
Low octane in a high compression engine will cause gas to ignite under the compression (much like a diesel that has no spark plugs.) It's supposed to ignite when the spark plug fires, so you may end up with pinging or knocking. That is not good, and I would get some 93 octane in there as soon as possible. Hopefully you don't have too much of the low octane to be diluted by the high.
Old Sep 4, 2005 | 11:11 AM
LB04CE's Avatar
LB04CE
Yes the light will come on, afriend did the same thing, go get some
octane boast, put in, that will help,,he got his at Wally World.
Light should go out his did..............
Old Sep 4, 2005 | 11:23 AM
1Patriot's Avatar
1Patriot
I have refuled several corvettes at Wally World (Murphy Oil Company) and never a problem. Also refuel the Cadillacs at the same place.
Check the gas cap and make sure it is tight, then clear the codes and see if the error code reappears before getting excited. I ran my 04 C5 on a couple of tanks of regular, when premium was not available, and never had a problem. The onboard engine control computer is smarter than we are.Of course, i don't drag or do WOT very often.
Good luck with the fix.
Old Sep 4, 2005 | 02:27 PM
WWK888's Avatar
WWK888
Do you know how to pull the codes? If so, do so then at least you know what you are dealing with.
http://www.stengel.net/diccodes.htm
Old Sep 4, 2005 | 02:44 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
I've used 87 before and never got a check engine light, but it's not impossible. I agree you should check the code though, to make sure it isn't something more serious. As far as the ping/knocking, your vette has a knock sensor in it to stop that, hence the reason you have lessened engine performance using lower octane fuel. As someone partially described, the ONLY difference between low and high octane is the FLASHPOINT of the fuel, meaning the higher octane has a higher flashpoint. The ping/knock is just a result of premature combustion due to a low flashpoint, which again, the knock sensor compensates for.
Bottom line: check the codes, if it's the fuel, use the octane boost and it will be fine temporarily. The sky IS NOT falling....
Old Sep 4, 2005 | 06:26 PM
Ubenripped's Avatar
Ubenripped
I knew about the traction control codes because I already had it scheduled to go into the shop next week for that. Didn't know about the rest though. All of these occured recently.
This car has a randomly possessed electrical system. The motor runs great and doesn't eat oil but I have had all types of minor electrical gremlins in the past. PCM and BCM was replaced under warranty about a year ago for randomly losing communication with everything. Had the windshield wipers randomly decide to turn themselves on or off and the wiper controllers were replaced. Every now and then I notice the internal lights such as dash lights and radio lights change intensity but the dealer never seems to be able to reproduce a lot of the errors.
Anyway, here are the codes:
PCM
P1415 AIR System Bank 1
TCS
C1243 BPMV Pump Motor Stalled
LDCM
B2264 Vertical Position Sensor Fault
U1064 Loss of Communications with BCM
RDCM
B2283 Battery #1 Fault
B2285 Battery #2 Fault
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
Oh, and I cleared the codes last night and the check engine light was gone this morning. Still have the TCS problems though. I have to rescan in a little while and see if any of the others came back.
Old Sep 4, 2005 | 08:10 PM
MyToyC5's Avatar
MyToyC5
Gas Cap not tight is number one cause for this if you recently filled up.
Old Sep 4, 2005 | 09:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NONE of those would be fuel related!!!!! After you clear the codes, monitor the DTC for any receint codes and post them. My guess is that the code was sporatic and should clear.
The TCS code is another animal and need further troublechooting. What year car and what mods??
BC
Old Sep 4, 2005 | 09:20 PM
Ubenripped's Avatar
Ubenripped
BC
It is a 1999. No real engine mods just K&N filter. I installed a HUD about 1 1/2 years ago. Other than that it is stock.
The only code that came back is C1243 BPMV Pump Motor Stalled.
It disables my TC and ABS and says "Service Traction Control" and "Service ABS". It does it as soon as you start the vehicle.
To Can low octane gas cause check engine light?
