Tread depth for roadracing
Old Sep 14, 2005 | 11:32 AM
dbirdz06's Avatar
dbirdz06
Default Tread depth for roadracing
I was trying to decide if my front tires needed to be replaced before I went to a two day DE roadracing event. I have the stock F1's with about a 32nd above the tread indicator markings. Ideally, I would like to run these and replace them afterwards. How would they fair for tech. inspection, grip, and longevity?
On another note, does anyone have a good link or tips to bleeding brake lines?
Old Sep 14, 2005 | 01:17 PM
Skull One's Avatar
Skull One
You may pass but you won't have any tread for the second day. And the bigger concern would be wet weather. If they run rain or shine, you will have to sit it out if there is more than a sprinkle. 1/32 in rain is a good way to undeersteer/hydroplane in to a wall.
Old Sep 14, 2005 | 03:57 PM
2kbluestreak's Avatar
2kbluestreak
I have the same concern, trying to get one more track day out of my Kumho MX's. Front tread depth is 4mm and the rear is 5mm. Kumho says to scrap the tires at 1.5mm. So, they should be good for one track day, but I'll have to really cool it if it rains. I think the best $500 option I spent on my 2k was the Active Handling.
Old Sep 14, 2005 | 04:14 PM
Vette5.5's Avatar
Vette5.5
I replaced my stock F1's with OEM rubber at 4 years and 31K on them. The tread actually looked pretty good, but they just wouldn't stick, due to aging & heat cycling. I wouldn't have raced my car with those tires. The New OEM's grab much better, although with slightly less response, due to increased tread depth. You're tires may have aged better than mine. It's something you might want to look into.
Old Sep 14, 2005 | 04:24 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
I agree with the above comment that you may make it the first day, but probably not the second, and you certainly wouldnt like it in the rain.
Which DE event are you looking at... I am heading back to MSR in November for the clockwise run... Maybe I'll see you there...
Old Sep 14, 2005 | 04:41 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Its been a long time since I've run a pure street tire at a DE, but agree with the others that you will likely be in the threads, particularly on the outer or inner corners, before the weekend is over. I think the answers to your questions about tech are very dependent on the group you are running the DE with and I would ask others that have run with that group, or the group itself. Grip will decrease with age, but probably insignificantly for a DE (unless it rains...). Longevity will be short: keep a close eye on both the inner and outer edges for signs of the threads showing through.
After my first DE, I broke down and bought a second set of wheels so I could use more dedicated track tires that are less expensive than the stock F1SCs (such as the Kumho Victoracers which are a good DE tire). However, this is a downhill spiral as it complicates how you get to the track, as clearly a second set of wheels and tires won't fit in the C5/Z06. Before you know it you will have a trailer, a huge pickup truck, and heck, from that point why not just weld a cage in it and go racing...
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 14, 2005 | 05:12 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I've got 22000 on my Z stock tires and I'm replacing them 1 week before I go to the Poconos Oct1&2. I want excellent traction on the north course
Old Sep 14, 2005 | 06:24 PM
AU N EGL's Avatar
AU N EGL
1/32 is PERFECT The less tread the better. Tread is only to move water away from the tire for grip in the rain.
When you have TOO much tread the likelyhood of seperating the tread from the tire carcus is greater, or the causing the tread to bubble. On new treaded rubber remeber to never weave to put heat in the tire all you do is cause the tread to chunk or bunch up.
Where as if you have no to very little tread the car will handle far better as you will have more grip. Slicks have better grip as there is more rubber on the track with no tread or DOT slicks with 2/32 tread.
Now the other aspect of the tire is its age. How old is the tire?? A tires real life span no matter how many miles is about 2 years. After 2 years the rubber is TOO HARD and provides minimal grip.
Tire pressue should be about 30 PSI cold
For more info on track days or HPDEs come over to the Corvette General section under Autocross and Road racing. Lots of good info there and the Stick above will give you almost all the links you need.
Lots of good ppl there too
Tracks time becomes an addiction, just like trying to eat ONE potato chip . . .
Old Sep 14, 2005 | 07:26 PM
dbirdz06's Avatar
dbirdz06
The tires have about 24k on them right now, they're the stock tires that came on my '02 unless the guy before me replaced them. But I hope not since I bought the car with 4900 miles. The tires are well over the 2 years you mention but I am planning on running these as long as they will last. Hopefully through the weekend. Being my first DE experience, I will likely not know the difference in a perfect tire and a good tire, but we will see. I think I will have a blast one way or another!
Old Sep 14, 2005 | 07:46 PM
dbirdz06's Avatar
dbirdz06
I will be at Texas World Speedway in College Station, Tx. Not sure that it's very close to you...I'll have to pass on the MSR (I don't even know what that stands for )
Old Sep 14, 2005 | 09:49 PM
GeorgeZNJ's Avatar
GeorgeZNJ
so i guess i should leave my tires on and put the new ones on the car when i get back?
Old Sep 15, 2005 | 09:06 AM
AU N EGL's Avatar
AU N EGL
Yes your current tires will be fine and have fun out there
Put your new tires on when you get back.
Old Sep 15, 2005 | 12:42 PM
GeorgeZNJ's Avatar
GeorgeZNJ
thanks, only second time to road course, but many more to come
Old Sep 15, 2005 | 01:46 PM
dbirdz06's Avatar
dbirdz06
I have a feeling I will be saying the same thing
Old Sep 15, 2005 | 03:09 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
I have done a couple of events with Drivers Edge. It is a pretty good drive to Texas World Speedway (TWS) about 9 hours for me... Motorsport Ranch (MSR) is in Cresson, TX and is about 8 hours for me... But me and a couple of buddies like to run together so we find places that are in the middle for all of us... I dont know if I am going to TWS this go round, but I am sure after you go once, we'll meet somewhere... Enjoy the madness... Driver's Edge puts on a great event... Rick and his crew are top notch...
Jason
My signature photo is from Motorsport Ranch....
Old Sep 15, 2005 | 03:21 PM
edensknight's Avatar
edensknight
I agree with "Au n Egl" above. As food for thought, most races (i.e., Nascar) run with tires that are between 2 to 3/32 of tread depth only. A racing team will typically go through up to 15 sets of tires over a race weekend. Again, in this specific example, the lower tread depth provides better traction and performance on the race track. Enjoy, and, be safe.
Old Sep 15, 2005 | 03:31 PM
Billy182's Avatar
Billy182
Heat cycled too many times??? That would be my number one concern. Did you start off with shaved tires??? Just be careful after warming them up, you wouldn't want to find out too late (off the track at turn one!) that your tires are way past their prime.
I use to run R1's, and when unshaved tires got down to your tire's depth, they slid tremendously.
Old Sep 16, 2005 | 06:53 AM
AU N EGL's Avatar
AU N EGL
Always take a lap to lap and half to warm up your tires.
Tires that I have run in the past and how much use I got out of them
Mich PS 10 weekends and still have tread remaining. My first 10 DEs.
Hoosier GACs 4 weekends
Good Year Eagle G19 R480s 5 weekeds a set
Good Year Eagle G19 R 370s 1 weekend ( Very soft compound)
Hoosier VRL 4 weekends a set.
The Hoosiers and Good Years are full slicks
The Mich PS were great the Hoosier GACs had 10 times the grip as the Mich, the GOOD Year G19s were twice the grip and the Hoosier GACs and the Hoosier VRLs are about the same as the Good Year G19s
I use the Hoosier VRLs now.
The longer the tire lasts the less grip it will have, so there are trade offs.
Be safe out there
To Tread depth for roadracing
