sway Bars
Just in case you're interested how the Hotchkis stack up against the various stock sway bar diameters, take a look at this.....
23mm, front; 19.1mm, rear --- FE1/Base --- Source
25.4mm, front; 21.7mm, rear --- FE3/Z51 97-99 --- Source
28.6mm, front; 23.6mm, rear --- FE3/Z51 00-04 --- Source
30.0mm, front; 23.6mm, rear --- FE4/Z06 --- Source
31.75mm, front; 25.4mm, rear --- Hotchkis --- Source
38.4mm, front; 27.5mm, rear --- GM T1 --- Source
Info courtesy of Leaftye
http://forums.corvetteforum.com/show...7&forum_id=103
We switched to Hotchkis & there was a huge difference! After that we added QA1 Adjustable Shocks...which provided even better handling. But even with those upgrades, it wasn't until we upgraded to Nitto Race Tires that the Corvette handled the track better than most cars there.
Did you replace your springs when you added the Hotchkis bars and the Bilstein shocks? If not, how long have you been running your current setup? Any problems or complaints? How's the ride?
Sorry for all the questions, but I've been thinking about going this route, but my car is a daily driver, so I don't want an extremely harsh ride or have to worry about the car bottoming out on everything all the time. I might start with stiffer sway bars and go from there.
Anyone else have any input or suggestions? Thanks!
Now - admittedly, the roads here in Arizona are not frost heaved or particularly rough. The freeways are generally well paved, and the secondary roads are a rough surface (like exposed aggregate), but little in the way of potholes, etc.
Out on the freeway at 75 - 80 mph ( Relax....the speed limit is 75mph away from town and 65 in most places) the car rides like a luxury car. when the road starts to twist, the car handles like it's on rails. I've driven on Rt 89 out of Prescott which is about 20 miles of switchbacks and tight turns with a posted suggested speed of 15mph, at speeds somewhat higher than that
and the car is like a slot car. It handles the way I'd expect a Corvette to handle. I have no illusions about the car - it's not a Z06, but it's not a Cadillac either. If I wanted a perfect soft and smooth ride, I wouldn't have bought a sportscar.I would have no problem using the car as it is today as a daily driver, but again it comes down to perception and expectations.
