drain plug.
Old Oct 10, 2005 | 02:02 PM
sal's 98 Vette's Avatar
sal's 98 Vette
Default drain plug.
This time i want to change my oil by my self.
is the drain plug close to oil filter? what size?
do i need to reset something or the computer recognize that the iol is new.
thanks for the help.
Old Oct 10, 2005 | 02:34 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
OIL CHANGE MADE EASY.
1. Take a short ride to warm up the oil to operating temp.
2. Put my car facing down in my driveway.
3. I use a low profile jack on the driver's side with a puck. Jack the car up five pumps
4. Put a jack stand under the A Frame
5. Oil drain pan under the filter
6. Put on a rubber glove and have a few paper towels handy.
7. remove the filter first, let it drain
8. remove the dirty filter from the drain pan
9. remove the drain plug let the oil drain (15mm socket)
10. remove the jack stand and lower the jack
11. go have a beer, about 15 minutes later, come back jack the car back up ( five pumps )
12. Lube the oil filter gasket with fresh oil and fill the filter with as much oil as you can get in there and install, clean off the oil drain plug and install.
13. Add the oil and start the engine check for leaks
14. pull out the drain pan
15. lower the car
16. reset the oil life monitor. Bring up the oil life on your DIC. Turn the key to ACC. and press the gass pedal 3 times.
17. Store the drained oil in a stable container to be recycled.
The End
Old Oct 10, 2005 | 02:39 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
To reset the oil life monitor, you can pump the gas peddle three times fully to the floor but you have to turn the key to the on position first (But don't start the car!)
Or... You can run thru the buttons on the dash and you'll figure it out.. I think it is when you get to the oil life monitor display, press the reset button then.. you may have to hold it a sec? Geez, it's been a few months since Spring.. I'm getting old and senile!!
I think you have the rest of the info...
Old Oct 10, 2005 | 03:39 PM
DeeGee's Avatar
DeeGee
MyVetteDreams write up is good advice.
Here's another tip page that was posted a while back. It has some pictures too:
http://www.97vette.com/howto/oil/index.html
Best of luck. I'm gearing up to do my next change myself as the Stealer charges $80+ for $25 worth of oil and filter.
To drain plug.
