Starting problem
Old Oct 14, 2005 | 11:33 PM
dragboatnolen's Avatar
dragboatnolen
Default Starting problem
I posted on the tech site before and had no response, has anyone had starting problems. It takes two turns of the key to start my 2004 LS1. The dealer says it is not normal, but yet cannot fix it. After it is started, will start right back up. Have had it in 2x replacing the whole ingnition switch in total. Any suggestions?
Old Oct 14, 2005 | 11:58 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Thats strange. Maybe somebody will chime in.
Old Oct 15, 2005 | 12:04 AM
DaBoz's Avatar
DaBoz
I was having some issues.... I started holding the key to the right (start position) for a fraction of a second longer after it started. No more issues.
Old Oct 15, 2005 | 12:10 AM
dragboatnolen
Will try, I thought I have tried every way, letting off quicker, letting the pump build up, I don't know. It is frustrating!
Old Oct 15, 2005 | 12:16 AM
DaBoz's Avatar
DaBoz
Mine would start, then stall. Then I'd have to turn it over 1-3 more times before it'd catch again. By holding a bit longer, it's never happened again.
Old Oct 15, 2005 | 12:20 AM
GrayC5's Avatar
GrayC5
No this is not normal. My guess would be either a bad ignition switch, bad key resistor pellet or dirty key. You said they replaced the ignition switch twice. Do you have the same problem with both keys?
The dealer's shops have access to GM technical assistance for problems they're having difficulty resolving. Has your dealer's shop contacted them? Sounds as if you may not be getting the assistance from this dealer that you should. If this dealer can't resolve your problem, you may want to find another dealer. Also, you may want to review Section 7, Customer Assistance Information in your owner's manual.
Good luck with the fix.
Old Oct 15, 2005 | 12:29 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
I just had this issue. DO NOT IGNORE IT!!! it will not get better.
Mine turned out to be an internall shorted battery that left me stranded in St. Louis.
Old Oct 15, 2005 | 12:40 AM
JoshVette's Avatar
JoshVette
I had a similar problem once.
Two things I'd do...........
First take all the keys off your keyring and just let it be your vette key and fob.........the weight from the other keys can cause the pellet (chip) in the key to loose contact with the ignition cylinder, thus causing the car to think the it's trying to be started without the proper keys.....this will temporarily shut down your ignition and fuel system (it's a security measure).
Second. When starting your vette, turn it on but don't start it, let it cycle the fuel through into the engine before you it. I had problems with it starting rough and once I did these two things I haven't had the problem yet.
Old Oct 15, 2005 | 10:46 AM
DeeGee's Avatar
DeeGee
Dieing Batteries can cause all sorts of weird issues.
Do you have another battery you could try. That would prove whether its the battery or not.
Old Oct 15, 2005 | 10:55 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Try checkig these two threads... Hopefully one will help you ...
I know what a PITA it is to track down these issues.... Hang in there.
Dave Q.
http://forums.corvetteforum.com/show...p&forum_id=103
http://forums.corvetteforum.com/show...421&forum_id=1
Old Oct 15, 2005 | 01:57 PM
dpd's Avatar
dpd
sounds like you have a bleed off issue.your car is running ffs.inside your tanks you have 2 fuel pressure regulators, 1 in each tank,1 is in the left tank and 1 is in the right tank.the 1 in the left tank maintains rail pressure and the 1 in the right tank basically keeps fuel from bleeding out of the left tank and back into the right.the way our fuel system is designed[late 03 to now],it is a returnless systm,it must use the fuel in the right tank before it will use the left tank[there is a syphoning jet pump in the right tank that pushes fuel over to the left tank into the pump bucket.short and sweet,check fuel pressure..hook up a pressure gauge[dealer SHOULD know this].start the car,shut it off,let the car sit overnight,look at pressure gauge.if it reads 0,the fuel system is bleeding off.problem can be any of the regulators,jet pump hanging open,etc.
Old Oct 15, 2005 | 03:12 PM
JoshVette's Avatar
JoshVette
Have you checked you codes yet??
Do you have any codes showing??
Old Oct 15, 2005 | 03:29 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Hi,
What is your internal shorted battery problem?
I went out last night and after shopping with my wife, come back and the car would not start ... there is no click or anything. I have had this problem but after couple tries, it would work. But this time, it is not working.
We have tried to jump the battery , etc ... an finally, we gotta push it in second gear and pop it to start. So we got home with vette last night and I hope it would work today but it still not.
I am reading all the old posts now ...
Thanks,
-Mike
To Starting problem
