Automatic Shift Knob Adapter
Old Oct 24, 2005 | 08:24 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Automatic Shift **** Adapter
Is anyone else outraged by the price of these conversion kits? It looks like it is basically a spring and a piece of plastic with a screw. Are people really paying $50 for these or is there a DIY shortcut? Please tell me someone has the secret! thanks
Old Oct 24, 2005 | 08:35 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Brian, it's a bit more than a spring and plastic adapter.
It's made of steel and is black anodized and has a cap for your stock shift boot
Old Oct 24, 2005 | 08:45 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
......sure, justify the corvette tax . i see so many nice 6 speed ***** out there, but i guess there is no real shortcut
Old Oct 24, 2005 | 08:48 PM
0EG@EnglandGreen
Supporting Tuner
I felt the same way before I bought mine, but I can't see an easy way around it short of changing the entire shift lever (which I wish someone would offer)
Old Oct 24, 2005 | 08:52 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
The better one is how West Coast Corvettes WILL NOT sell you just the adapter (Thanks Craig)... they will however, sell it to you for $50 IF you buy one of the $90 ***** as well... I tried a while back... I was told "Try the internet." No thanks... I kept my $130.00
I went to a buddy's shop and he handed me a $100 **** for FREE. I took a 1/2" x 1" metal dowel and made "my own" adapter.
Old Oct 24, 2005 | 08:59 PM
White Dually's Avatar
White Dually
O.K. here is my stupid question for the day. How do you remove the **** on an Automatic?
Thanks,
Fred
1998 Nassau Blue
Old Oct 24, 2005 | 09:03 PM
MyVetteDream
Thanks,
Fred
1998 Nassau Blue
Not stupid:
There is a big staple looking pin holding it onto the shaft.
Look at the front of the **** (as if you're sitting facing the rear of the car)
Take a small, flathead screwdriver and insert just the tip (as if you're prying the staple out) and pry out just the edge a little.
Take a pair of needle nose pliers and plug the staple out about half way. The **** will pull right off the shaft.
Old Oct 24, 2005 | 09:04 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Thanks,
Fred
1998 Nassau Blue
http://www.vetteessentials.com/instr...t_install.html
Old Oct 24, 2005 | 09:14 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
dave, could you give some info on how you made your adapter. it sounds pretty cool. thanks
Old Oct 24, 2005 | 09:18 PM
White Dually
Thanks for the Help. Didn't mean to Hi-Jack this Thread.
Fred
1998 Nassau Blue Coupe
Old Oct 24, 2005 | 09:24 PM
MyVetteDream
Sure Bri-
I guess the big question would be what kind of **** you have. I got this one... it has the shift release **** in the middle. I just measured out how much I needed and inserted it into the ****. It filled the gap.
Old Oct 24, 2005 | 09:25 PM
Cheech Wizard's Avatar
Cheech Wizard
Here's the lowest price I've found for the adaptor-$30.00
http://www.xmsengineering.com/interior/
Old Oct 24, 2005 | 11:48 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VII Veteran
beat me to the post
Old Oct 25, 2005 | 12:54 AM
MR1911's Avatar
MR1911
Although I have not been inside my new C5 shifter YET , I have been inside the f-body shifter and assume its pretty close to the same inside.What I have done is cut the plastic stick that actuates the detent , and replaced it with a longer metal rod(actually I like to use an old push rod ) so that it becomes the button, then drill a hole in the center of any **** you want to use.Mount new **** to shifter shaft and off you go.A side benefit to this is you can just pull the rod out and stick it in your back pocket ,no shift, no steal Works good been doing it since the 80's
Old Oct 25, 2005 | 05:55 AM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Awesome, thanks for the link! I almost spent the $50 @ Ecklers for their adapter kit.
Ice,
Thanks for the topic! Saved me $20 of Vette tax.
To Automatic Shift Knob Adapter
