Sticky Question
Old Nov 5, 2005 | 07:13 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Default Sticky Question
The thread is certainly loaded with information. If someone wouldn't mind please help me with the following listed under Secrets of the C5,
The build sheet is in the front re-bar. What is the front re-bar?
Simply remove fuse #2 under the hood and your DRLs will be out permanently What is a DRL?
Thanks in advance
Bob
Old Nov 5, 2005 | 07:26 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Bobby G.
The front rebar is actually the space between the frame and the front bumper. It is located behind the front fascia.
The DRL is the Daytime running lights that are located beside the turnsignals in the front of the car....these are the lights that are on all the time when the car is running.
Paul
Old Nov 5, 2005 | 07:30 PM
BobbyG's Avatar
BobbyG
Originally Posted by talon90
Bobby G.
Paul
Paul,
Thanks for the reply, I'm still learning.
Bob
To Sticky Question
