In regular traffic thats moving I leave it in D. If the traffic slows I'll use 2 to stop it hunting.
Wanted to check out acceleration and braking with my new PS2s yesterday. Entered the local stretch of freeway which is quiet out of town. Left it in 2 and accelerated hard to the speed limit before slowing right down. I forgot just how awesome this car is
I often have mine in 2nd gear going light to light. From a stop with A4 in 2nd, doesn't it start in 1st ?
Mark
I don't know if you are being serious about that question, but the answer is "No." If you start off with the selector in "2", then you will start off in 2nd gear. The 2002 Owner Manual states (p. 2-30):
"If you manually select SECOND (2) when you start the
vehicle, the transmission will drive (and stay) in second
gear. You may use this feature for reducing torque to
the rear wheels when you are trying to start your vehicle
from a stop on slippery road surfaces, or for preventing
the transmission from downshifting into FIRST (1) in
situations where a downshift would be undesirable."
To show people like you a clean set of taillights, of course.
I have spanked many a MN6/MN12 driver that assumed (just like you) that your car was way faster than mine - or even better yet - naturally assumed that you were a much better driver than I am.
No Offence to anyone with an A4. When asked why I have a MN6, My responce is simple." I wanted an automatic, I would have purcheased a Caddilac"
As with any mechanical device the transmission has only so many duty cycles in it. It may be 10 million or 20 million, or whatever, so manually shifting when it's not necessary simply uses more of these finite cycles. So, if you want to play, be prepared to pay. The engineers have designed automatic transmissions to be AUTOMATIC. The computer figures out the best gear to be in, and uses sensors to find the best combination on modern cars.
I know, nobody wants to hear this (including Me). Nobody wants to really know the negative sides of shifting in Auto cars (including Me), cuz we all like to do that. So, WHY DO we even bother asking such questions ? Cuz deep down inside, we know better. But we're just looking for "others" opinions & approval, to help us steer our own. Bottom line - Your tranny will go bad if you shift it manually a lot. I've done it in the past, after which I did research, and was told by professionals to not do it. So, I stay away from shifting all the time. As someone here said they changed their gears and stall TC, and leaving it in D gives them enough power "All the time", with some Dyno tune help.
Having said that, I do shift sometimes in traffic to 2nd to just pass up some cars quickly, or change lanes. Either way, hope that helps...
I don't agree with you. Do you have any links/articles to back that up?
I might agree if someone is just cruising down the highway, and shifting up and down the gears just for the heck of it. But usually I'll downshift/upshift manually in those situations where the tranny would have done it anyway, but I wanted it to shift now, rather than a few moments from now. Under those circumstances, the tranny isn't being put through any more duty cycles than having it in "D".
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Correct.
Everyone seems to forget - it's a transmission.
Whether "automatic" or manual - gears still have to be selected and torque multiplication still has to take place. I love hearing the "if I shift it, I will break it" mantra.
So here's what we can do. For the timid, please leave your automatic in OD and I'll continue to shift my "automatic" like a ****. How's that?
Hot Rod the A4 and you will burn clutches sooner. Ok if you don't mind a premature tranny wear out. An unmodified A4 is a marginal tranny at best for manual shifting. Shift out of OD for around town, otherwise leave it in drive. If that is not a low enough gear, change the rear end and don't mess with the A4 unless you plan to rebuild and modify it early.
You know...as much as people like to argue back and forth about this topic, whether it is harmful to shift the A4 manually; however, there is a concrete answer. You might find that the correct answer lies somethere in between "perfectly fine" and "should never do it". I suspect the correct answer will have much to do with frequency and circumstance.
We need someone with actual mechanical knowledge who can speak on this subject with authority, not anecdotal evidence, but actual authority based on scientific type mechanical training to respond to this question.
"Hot Rodding" is always harder on the parts involved, there's no question about that. But what is the difference if I manually downshift it, or if I just floor the accelerator and the tranny then downshifts? The same speeds are involved, and the same gear is selected.
As another point, there are times when I want to downshift to pass, without necessarily flooring the accelerator. It would seem that I'm being easier on the car by manually downshifting and accelerating mildly, rather than going *****-to-the-wall and letting the tranny finally catch on that a downshift would be appropriate.
From: "Second place is just the first loser" Edmond, Oklahoma
this is absolutely correct...........those who know start in 1st or 3rd.... unless you're purposely playing with someone........ but any type of 'off the line' quick start requires anything but 2nd............. and to those involved in the 'damage to the transmission' crap, i recently replaced the 4L60E in my 98 coupe (134,000 miles) - not because I needed to, but because i was swapping the diff and had an 18k used tranny sitting around waiting.........actually waiting for a long time (running a 2004 LS6 with about 380 rwhp in front of it too). My 99 MN6 coupe (84,000 miles) doesn't have 4th gear anymore and it's been babied all it's life. Calling the 4L60E a weak tranny is so much bullsheat that I'm gonna go out and wash my taillights for you........watch for a blur of silver........
Circumstances and frequency are surely a key thing here... There's a line in between "NEVER do it, and ALWAYS do it". I guess, "sometimes", under certain circumstances won't hurt it. But as I mentioned earlier, I used to do it "all the time", and in about less than a year, I messed up my Tranny and needed a rebuild. Now if you don't mind rebuilding, or upgrading... then there's not problem. BUT just keep that in mind, you're gonna need to visit a rebuild/repair shop sooner than later...
