Pull key, wait 10 seconds
Old Nov 25, 2005 | 01:18 AM
lickitydoo's Avatar
lickitydoo
Default Pull key, wait 10 seconds
What does this message mean???? Just tried to start my car and nothing happened. Tried to jump it and still nothing. Lights under the hood are on and all other lights operational. While trying to jump it, the above message came on "pull key wait 10 seconds". What can I do? My car is at a bar in not the best area of town. I dont really want to leave it there over night. Need help.
Old Nov 25, 2005 | 01:20 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Does the engine turn over?
Old Nov 25, 2005 | 01:22 AM
lickitydoo's Avatar
lickitydoo
Nothing happens. The engine does not turn at all.
Old Nov 25, 2005 | 01:25 AM
mvvette97's Avatar
mvvette97
I assume you pulled the key and waited the 10 sec? If you did then turn the headlights on to see if they are bright. If they are dim then the battery is low. Even if it was low the under hood light may still be bright.
Old Nov 25, 2005 | 01:33 AM
lickitydoo's Avatar
lickitydoo
I did try to jump it though.
Old Nov 25, 2005 | 01:35 AM
Shane_S's Avatar
Shane_S
Are the headlights bright when you turn them on? Your car might think it's being stolen. I dont know anything about the vette's anti-theft system though.
Shane
Old Nov 25, 2005 | 01:36 AM
michael wyborny's Avatar
michael wyborny
TOW IT! typically 50-100 buck? It's worth it for peice of mind that's your babes safe. I would!
Old Nov 25, 2005 | 01:39 AM
mvvette97's Avatar
mvvette97
On the passenger side floorboard pull the cover off for the fuse access and pull #25 fuse and let it set for 10 min. then plug it back in and then hopefully it will start.
lickitydoo's Avatar
lickitydoo
Well I never turned the headlights on so I dont know how bright they are. It is real cold tonight so I never thought to turn the lights on sinse I had the jumper cables on.
Old Nov 25, 2005 | 01:40 AM
Shane_S's Avatar
Shane_S
Yes the fuse, forgot about that, make the computer forget. Then it might start. But be sure to check the headlights like was said earlier.
Old Nov 25, 2005 | 01:41 AM
lickitydoo's Avatar
lickitydoo
What fuse is this? I might have to go try it. I will have to get a ride back to my car. What makes you think this could be it? By the way I really appreciate your help!!!
mvvette97's Avatar
mvvette97
When you pull #25 fuse it should reset the security as I said in my reply above.
Old Nov 25, 2005 | 01:46 AM
mvvette97's Avatar
mvvette97
Fuse #25 is for the body control module. If you have the owners manual look under fuses. It will show you where #25 is.
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
I had this happen, but engine would turn over, but not start until I did "AS DIRECTED". Maybe unhook the battery cable (SAFTEY FIRST) to reset the computer? GOOD LUCK & BE SAFE!!!
Old Nov 25, 2005 | 01:47 AM
lickitydoo's Avatar
lickitydoo
I will go try that. Thanks a bunch!!!!
Old Nov 25, 2005 | 01:50 AM
mvvette97's Avatar
mvvette97
I know when installing the CLB you will get the pull key message and it says to pull that fuse to get rid of the message . Maybe it will clear it off yours also. Good luck.
Old Nov 25, 2005 | 01:55 AM
WWK888's Avatar
WWK888
I never got that message when I installed my CLB.
To Pull key, wait 10 seconds
Old Nov 25, 2005 | 02:05 AM
Shane_S's Avatar
Shane_S
Idiot question. CLB?
mvvette97's Avatar
mvvette97
I did, then it also happened tonight.
Old Nov 25, 2005 | 02:06 AM
WWK888's Avatar
WWK888
CLB=Column Lock Bypass kit
