300mph C5???
Old Dec 6, 2005 | 01:10 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Everybody points out the Bugatti, and the butt loads of power the bi-twin turbo set up has. However nobody's mentioned the technology in that car to make it accomplish 250mph. The aerodynamics change on the car, as do a few other things. When the Bugatti is in top speed mode, it is not safe to drive in traffic, and the first time you touch the brakes it goes back to sport mode. The only time you can get into top speed mode is at a stop with the engine running.
I read a very interesting article on the car it's amazing the technology involved in going 250mph safely. I don't foresee a corvette with only basic steering rack set up, basic non-adjustable suspension, safely approaching anywhere near 300mph, let alone never catching up to the bugati's 250mph.
Chris
Old Dec 6, 2005 | 01:21 PM
BlackMagicC5's Avatar
BlackMagicC5
I don't care how much horsepower it has, it will not do 300mph. Some of you guys sound crazy actually thinking its possible. Have any of you ever been to 200mph? Do you actually think it'll just cruise right up to 300mph without any serious issues?
Old Dec 6, 2005 | 01:24 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
...cant see it.
A Top Fueler makes around 6500 Hp and it weighs in at slightly over 2100. It took until 1996 to reach 300. Now I understand that this is only in 1/4 mile but look at some of the cars on the dry lakes with the same HP and weight....they reach about 230
Old Dec 6, 2005 | 01:42 PM
Pentacle One's Avatar
Pentacle One
Let me dive it and I will find out
Old Dec 6, 2005 | 02:24 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by stsears1
What about with an ironing board bolted to the back???? Hahahaha..........
Ironing board is only good to 192mph. You have to go to the park bench model to break 200mph....
Old Dec 6, 2005 | 03:16 PM
ecudooberhead's Avatar
ecudooberhead
The gearing (among MANY other things) would make is impossible to hit 300mph
Old Dec 6, 2005 | 03:17 PM
C6this's Avatar
C6this
Rember the bugatti veyron weighs around 4000 pounds and the vette only ways about 3100 pounds. Plus I am sure that LPE shaves off a lot of weight when building a monster like this. I think its possible....call me crazy........
Old Dec 6, 2005 | 03:30 PM
ecudooberhead
Weight has no bearing on top speed "what so ever". Top speed is simply a function of power vs. aerodynamic drag. Aerodynamic drag does not increase linearly, this is why you see a 1000+hp car hitting "only" 250mph. It's very unlikely that a modified "production car" will hit 300mph anytime soon, unless your definition of "modified" is radical enough to include a completely redesigned suspension, chasis, body panels and engine.
Ahmet
Old Dec 6, 2005 | 03:32 PM
Ahmet's Avatar
Ahmet
Navigator
Ahmet
Old Dec 6, 2005 | 08:06 PM
1998 GTR's Avatar
1998 GTR
Hey, THAT might do it! . . . If it had one of those Teflon covers on it!
Old Dec 6, 2005 | 08:11 PM
1998 GTR's Avatar
1998 GTR
Originally Posted by sage666
Probably meant 300 KPH, not MPH...
That would only be 180mph. I know a Lingenfelter 427 TT would hit that without even breathing hard. Naw, I think the guy's trying to sell the 300mph number.
Old Dec 6, 2005 | 08:14 PM
1998 GTR's Avatar
1998 GTR
Okay . . . You're CRAZY!
Old Dec 6, 2005 | 08:19 PM
  #33
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Maybe on another planet with a thinner atmosphere
Old Dec 6, 2005 | 08:21 PM
  #34
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Euro dash gauges....
VR
Old Dec 6, 2005 | 08:22 PM
  #35
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Default 300mph? Maybe on a dyno!
Here's an interesting calculator which addresses this topic:
http://www.rbracing-rsr.com/aerohpcalc.html
It is intended for bikes, but seems to scale to 4 wheeled vehicles if the proper variables are plugged in. Here are the figures for a C5 coupe, which has the best chance of succeeding (right ), since it has better aerodynamics than the Z06:
Cd = .29
Frontal area = 21.3
Weight = 3210 + your weight *
Speed = 300
* Add weight if you have the typical s/s catback; subtract weight if you have the Z06 Ti.
After adding in my weight, it would take over 1217rwhp to propel me to 300mph (assuming the Z-rated tires don't explode or the car become airborne first).
Old Dec 6, 2005 | 08:41 PM
  #36
Dark-Knight's Avatar
Dark-Knight
Don't think so...
Old Dec 6, 2005 | 09:11 PM
  #37
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Look at it this way.. a NASCAR puts out sonmething like 800 HP and Bill Elliott set the speed record of 212 at Talladega.. no way is a 900 HP car reaching 300 MPH.
Slap a JATO pack on ith THEN you might have something
To 300mph C5???
Old Dec 6, 2005 | 09:47 PM
  #38
johninar's Avatar
johninar
It it's got a hood seal I'm sure it will hit 290 for sure.
Old Dec 6, 2005 | 11:01 PM
  #39
UncleRobb's Avatar
UncleRobb
Here's the math:
The power P needed to reach a speed v in a car is approximately proportional to the cube of the latter,
P ~ v^3......................(1)
With
P' ~ v'^3.....................(2)
and dividing Eq. (1) by Eq. (2) and multiplying both sides by P', we get a formula to estimate the power P needed to achieve a speed v when the car reaches a speed v' with a power P'
P = P' (v/v')^3..............(3)
Thus, with P'=350 hp, v'=175 mph, and v=300 mph, we get P=1763 hp. Moreover, we may solve Eq. (3) for v, to obtain the top speed at a given power P,
v = cube root(P/P') v'.....(4)
With P=992 hp, P'=350 hp, and v=175 mph, we get v=248 mph. Remark: I used engine powers instead of rear wheel powers. However, assuming that the losses in the drive train are proportional to the engine power, the above calculation is unchanged if we insert rear wheel powers for P and P'.
Its great to be a theoretical physicist
Old Dec 7, 2005 | 02:53 AM
  #40
StevieB's Avatar
StevieB
Originally Posted by bobdt173
To do 300mph the car would have to have some major body mods to hold it to the ground. I think the stock body is only rated to 200mph. This is only an opinion take it for what its worth.
Bob
Yea, there is no way a stock body could do that without becoming a short flight airplane.
