Ecklers has a pressure brake bleeder, item # 46104, that says it will work on any dual chamber master cylinder. It also states that it fits 1965 - 1982 Corvette master cylinders, sort of confusing.
It looks like a Motive system and I'd like to get some feedback on this unit. It's a small tank type that hold 2 quarts of fluid.
I dont know about that one , but if you have an air compressor I would get something that would connect to it rather than pump it. The one that I have can be used for any car , truck , bike, ect,its made by mightymite , but have seen it made by other companys as well and looks very close to that one on ecklers but no pump.
That is a Motive pressure bleeder and they are available in any number of catalogs. Both Summit Racing and Jeg's have them for a few bucks less and the shipping and handling will be less than the $11.50 that Eckler's charges for ground shipment.
Motive has different reservoir caps available so it can be used on almost any domestic or foreign car. The pump-up style works great at the track or wherever you don't have access to air pressure.
If you do a full brake fluid flush, it will take around a quart so having a container that big is very helpful as you don't have to stop and refill the M/C reservoir every so often.
