Door Panel Removal
Old Jan 10, 2006 | 09:59 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Default Door Panel Removal
Anyone got any know how and/or advice on removing the driver side door panel. Unfortunately the previous owner used the window to shut the door. The window rollers needs to be tightened back up. It's not bad, but not as snug as the passanger side.
THanks in advance!
tt
BTW, just got the Cingular Corsa ring tone. My wife no longer thinks I am going through a mid-life-crisis, now she just thinks I am totally nuts!
Old Jan 10, 2006 | 10:14 AM
LV_2_XLR8's Avatar
LV_2_XLR8
Lower the window first. Then pop off the little access panel behind the door pull. There will be a screw under the panel to remove. Next, pop off the door handle bezel. You will see a couple of slots just big enough for a screwdriver blade to help you push the tabs back. The bezel just snaps in place. Then just pull out sharply on the lower part of the door panel. There are "tree" pins that push into holes holding the lower part of the door panel in place. Finally, just lift up on the door panel and it will slide up and out of the window opening. That's all there is to it!
Old Jan 10, 2006 | 10:17 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
VE has a great write up...
http://www.vetteessentials.com/instr...or_handle.html
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Pics in the 9th row down.
Old Jan 10, 2006 | 10:18 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Thank you so much!
I should have to pay for such info so quickly, I just love you guys!
Thanks again
tt
Old Jan 10, 2006 | 10:19 AM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Search function works awesome:
http://forums.corvetteforum.com/show...l&forum_id=103
Old Jan 10, 2006 | 10:32 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Thanks for the pics!
JFYI: My wife is a New Orleans girl. My Big Boy Dalmatian is named "Breaux".
Good to hear from you.
Thanks,
tt
Old Jan 10, 2006 | 10:34 AM
Cajundude's Avatar
Cajundude
Thanks,
tt
Cool name!
My dog is Nola .
To Door Panel Removal
