Change It Or Leave It?
Old Jan 10, 2006 | 01:07 PM
JTAllen79's Avatar
JTAllen79
Default Change It Or Leave It?
Mobil1 has been in since last July/2000 miles. I'm going to drive it down to Florida in 3 weeks, a 2500 round trip. Car runs perfect, but sits alot. It should be ok, eh?
Old Jan 10, 2006 | 01:09 PM
Jim2003's Avatar
Jim2003
What does your DIC read on the percent of oil life left? Use the computer as a basis for change. The engineers put good logarythms in the formula to protect our engines.
Old Jan 10, 2006 | 01:17 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
what do you have to lose in changing the oil....just do it.
Old Jan 10, 2006 | 01:23 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
If it will make you feel better change it. The new synthetic oils are not damaged or do not degrade over that short of a time. I would drive it and then change after get back.
Old Jan 10, 2006 | 01:27 PM
c-5-steve's Avatar
c-5-steve
Go with the DIC
Old Jan 10, 2006 | 01:38 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Originally Posted by c-5-steve
Go with the DIC
or if you're straight find something else!
Old Jan 10, 2006 | 02:00 PM
gpotski's Avatar
gpotski
Old Jan 10, 2006 | 02:01 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Cheap insurance. I would change it.
Old Jan 10, 2006 | 02:20 PM
Tom/99's Avatar
Tom/99
I have been changing the oil in my 2004, every 2,500 miles. Change the old oil prior to your trip.
Old Jan 10, 2006 | 03:12 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I change the oil in mine every 1,500 miles, which is about what I put on it in a year. I know it's overkill, but it gives me peace-of-mind and I sleep well at night.
Old Jan 10, 2006 | 03:13 PM
Dave68's Avatar
Dave68
Leave it in. I change my C5's oil once per year (5000-5500 miles) and the D.I.C. normally shows that I have 20+% oil life remaining. Don't sweat the small stuff - leave it in and enjoy your trip.
Old Jan 10, 2006 | 03:17 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi John -
Change it. If not for the oil quality, do it just to take a good look around prior to the trip.
Of course, should you demonstrate that good of planning ahead, it will snow and you would drive the truck anyhow....
Call me tonight. It should be good Thursday for coming out and changing the oil on the lift.
best regards -
mqqn
Old Jan 10, 2006 | 03:23 PM
NSTG8R's Avatar
NSTG8R
im running about 10000 miles on this batch of oil .. i replaced the oil filter about 3-4 thousand miles ago and i plan to run this batch for a little while yet.
its just an incredible car.
food for thought.
Old Jan 10, 2006 | 03:33 PM
angman5's Avatar
angman5
I am in the oil business and can say that your oil is fine and will go much further than 3000 miles between changes. I change mine every 3000 give or take a few miles or if I drag raced I will change it afterwards everytime. That oil will not break down and lose it's lubricating properties anything less than 3000 is overkill but I know it makes all feel better.
Just my .02
Old Jan 10, 2006 | 03:41 PM
rcs128's Avatar
rcs128
Go by the DIC... today's oils last a long, long time, and the engineers know what they're doing with the recommended intervals. Heck, my turbocharged audi has a 10,000 mile interval for changes. (also synthetic oil).
I admit that I still change my oil more frequently than the manufacturer's recomendations, but at 2000 miles you're just wasting money and resources.
Old Jan 10, 2006 | 05:29 PM
I'd drive it and then change when you get back. Should have plenty of life left in the oil at this point.
Old Jan 10, 2006 | 05:37 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
To Change It Or Leave It?
Old Jan 10, 2006 | 05:45 PM
Baron138's Avatar
Baron138
Change the oil!
Old Jan 10, 2006 | 05:49 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
and go by the DIC, that's what it's there for Unless you race the car, I don't understand why people don't just follow the DIC.
Old Jan 10, 2006 | 05:50 PM
Evil-Twin's Avatar
Evil-Twin
I have posted this many times:
AS a former GM engineer working on the C5, I can assure you that hundreds of scenarios went into the development of the oil life monitoring system.. The algorithms "designed in" will still give you a ten % safety net. Actual oil testing under all types of extremes helped to develop this system.. anyone changing oil before the monitoring system says to is like flushing money down the toilet. There is something to be said for 1960's thinking... and that is "get some indoor plumbing, this is the New millennium" ... Oil life monitor % down to 0 or one year, whatever comes first. You still have a 10% safety blanket.
