What are these?
Old Jan 12, 2006 | 05:17 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Originally Posted by OUR97
I found one of these under each seat. Anybody have a clue as to what they are for? All power functions work ok. I fixed the rocking problem so I know they don't go in there.(too wide) [IMG][/IMG]
Just out of curiosity do you have the Selective Real Time Damping or Magnetic Ride Suspension? Those look similar to what the factory installs on each rear shock for shipping. The dealer removes them.
Old Jan 12, 2006 | 05:39 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
They are shaped like "C" and "I". Maybe its a hint that you should attend the Cruise In this year???
Old Jan 12, 2006 | 05:42 PM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
Originally Posted by KMeloney
I'm pretty sure it's a piecost.
Ohh, ohh, I love this one.....What is a piecost?
Old Jan 12, 2006 | 05:43 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Man if those are the shock stuffers those are some small shocks!
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default I don't know
Old Jan 12, 2006 | 06:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
About $2 45!! Depends if you want just a slice or the whole pie!!
Old Jan 12, 2006 | 06:41 PM
GR802C5's Avatar
GR802C5
Everyone should know that these are GM Part # 5003489 ; OEM Corvette, C5, Stand-off, white, teflon, C-shaped, Spacer, Control, Seat, Go-Figure's
Old Jan 12, 2006 | 06:46 PM
502ci's Avatar
502ci
ci..... did those fall off my signature?
Old Jan 12, 2006 | 06:52 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
...it's a henweigh...
Old Jan 12, 2006 | 06:55 PM
DBGMOO's Avatar
DBGMOO
reel him in he took the hook line and sinker.
Old Jan 12, 2006 | 06:59 PM
oaks99's Avatar
oaks99
there thingamabobs for the whatchamacallits
Old Jan 12, 2006 | 07:01 PM
chrisj's Avatar
chrisj
St. Jude Donor '12
Those are the clamps that allow you to bleed the blinker fluid. They are normally stored on the end of the fluid lines which you will find under the headlight motors. I'm not sure how they ended up in the car.
Have your service tech put them back on your next blinker bleed.
chris
Old Jan 12, 2006 | 07:19 PM
  #33
maddman's Avatar
maddman
Keep an eye on those things you will need them to swap out your muffler bearings when they go bad a common problem on the c5
Old Jan 12, 2006 | 07:53 PM
  #34
OUR97's Avatar
OUR97
No I don't have those options
Old Jan 12, 2006 | 08:06 PM
  #35
KMeloney's Avatar
KMeloney
LOL! Man, I'm glad someone got it! (I started thinking, "What if someone asks 'What are piecosts?' or 'What is a piecost?' and screws it all up?!" Thanks for playing along!
-Kirk
Old Jan 12, 2006 | 08:15 PM
  #36
AA2PR's Avatar
AA2PR
Actually they are electric ashhole spreaders.. dealers use them all the time when they fix your final price,
Old Jan 12, 2006 | 08:19 PM
  #37
AA2PR's Avatar
AA2PR
The cost of pie,what else ?
To What are these?
Old Jan 12, 2006 | 08:50 PM
  #38
ZOOOM's Avatar
ZOOOM
Youse guys are such DORKS!!!!
It's a J H Hammett 21212............
Go back and look!
However, I do not know what those plastic thingys are.......
ZOOOM
Old Jan 13, 2006 | 12:23 AM
  #39
Hotrodzz3's Avatar
Hotrodzz3
Probably are part of the seat tracks. I know that Ford seat tracks have similar looking parts used on the threaded rods used in power seats.
Bob
Old Jan 13, 2006 | 12:41 AM
  #40
gpotski's Avatar
gpotski
Those are the column lock nuts...you shouldn't have any problems with the column locking up on you now.
