Brake bleeder suggestions...
Need suggestions on what type of 'one person' brake bleeding device would be good to remove the old fluid and replace with fresh fluid?
Thanks...Jake T.
I bought speed bleeders because I change my fluid several times a year since the car is used on the track. I like them alot. Some people have had problems with certain brands, and some people have had trouble by stripping the caliper when installing the bleeders. Be careful. Bleeders will cost you ~$30 a set. The vacuum device probably costs that much. What you buy depends on how often you plan to do the job.
You could join your local Corvette Club and have a shop night where someone pumps the brakes while you turn the valve. Your only expense is the fluid, and you'll make friends in the process.
http://www.motiveproducts.com/02bleeders.html
Here's a word of warning for those who pump the brake pedal:
Limit the master cylinder's travel by placing a block of wood under the brake pedal. Pumping without it could allow your MC seals to be damaged by the cylinder bore's outer (never-used) areas. This is why I prefer the vacuum method.
