Engine Temp running hotter than normal ??
Old Jan 27, 2006 | 03:57 PM
jowens53's Avatar
jowens53
Default Engine Temp running hotter than normal ??
It caught my eye the other day....the engine temp was sitting at 240....I read a few articles indicating that 240 is not out of the norm. The problem is that I could swear it was never that high, and it seems as though the fan comes more than usual and is in a battle just to keep the temp at bay. The air temp is 55, and even very short trips get it up to 240. Is the thermostat going bad? Any advice or suggestions would be appretiated. I have checked under the front...no bags or debris on the front of the radiator. Thaxs-Jeff
Old Jan 27, 2006 | 04:05 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
how many miles on it, auto/manual, what year?
P.S. consider updating your profile with some info and maybe location with car year info like mine
Old Jan 27, 2006 | 04:16 PM
HummelS's Avatar
HummelS
Check for debris clogging the radiator - these cars are regular Hoovers when it comes to picking up trash.
Old Jan 27, 2006 | 04:41 PM
MHVette's Avatar
MHVette
Check that then check your fluid... Could be your Thermostat sticking but highly unlikely.
Old Jan 27, 2006 | 04:47 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
and then also check the fluid too, Thermo could be sticking
Old Jan 27, 2006 | 05:02 PM
jowens53's Avatar
jowens53
55k miles, Manual 2000...thanxs for the advice I'll dbl check for debris and check the fluid again...thanxs
Old Jan 27, 2006 | 05:13 PM
AU N EGL's Avatar
AU N EGL
after you check for junk and road clagg up in your radiators take a high pressure air hose and blow out the dirt and sand that gets in there too.
Old Jan 27, 2006 | 05:44 PM
jowens53's Avatar
jowens53
The fluid was low...hopefully that was it....I'll take a spin here shortly and see if that did the trick. Thanxs 2 all
To Engine Temp running hotter than normal ??
