Removing vinyl stripes?
Old Jan 29, 2006 | 11:33 AM
Rick@CTCORVETTE's Avatar
0Rick@CTCORVETTE
Former Vendor
Default Removing vinyl stripes?
For anyone who has done this do you have tips for me. I plan on using a hair dryer and just pulling them off. I don't want to damage the paint in any way. Any help would be great.
Old Jan 29, 2006 | 11:40 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Your plan sounds like a good one. Use a hairdryer to soften the material and adhesive and pull the graphic back over itself. Keep the heat and the pressure steady but not too much and you should be good. Just be patient.
Old Jan 29, 2006 | 11:59 AM
0Rick@CTCORVETTE
Former Vendor
Has anybody had problems removing vinyl graphics?? They have only been on for 5 months btw.
Old Jan 29, 2006 | 12:13 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
talon90's suggestion is right on the money. We do this with aircraft frequently in my business using a heat gun. You can't do any harm with a blow dryer. You won't have any problems. It just takes some time
Old Jan 29, 2006 | 01:16 PM
00247's Avatar
00247
Hopefully, the vinyl is a high grade strippable product. Many of the newer vinyls are rated strippable for up to 5 years. Seeing that it is relatively new, it should come off easily. Warm it up, pick at it very carefully, and pull it back at 180 degrees if the material will hold together. With luck the adhesive will pull with the decal. If it doesn't, try more or less heat. Some times warming the surface completely and waiting for the vinyl to cool slightly helps the adhesive stay with the vinyl. If the vinyl is to warm compared to the surface the adhesive will let loose of the vinyl and stay. If adhesive stays on you may need to use solvents to remove it. Mineral spirits are mild, most paints will tolerate it. Some of the oem paints can even handle lacquer thinner.There are citrus based removers, goo removers, and even WD40 will work for small amounts. Make sure you test in an inconspicuous place as paint damage can occur. You may need to buff the area after removal of the vinyl. There are so many variables. How do I know? I install and remove large format graphics on hundreds of commercial trucks each year. We are currently struggling with some Avery material custom printed by Modagraghics. It is virtually impossible to remove with out severe damage to the surface. Talk about a PITA! If you have problems free to PM me, I will try to help.
Old Jan 29, 2006 | 01:44 PM
Dyno Dan's Avatar
Dyno Dan
First, I agree with the comments above comepletely.
The only other thing I would be curious about is a color diff from under the decal to rest of car. What color is your car and what type of vinyl was the graphic. If it was a cross-linked polymer, hopefully you wont have a color diff underneath (kinda like what bras do for you)
Even though its only been on for 5mos, it all depends what the UV exposure has been.
Im just scared when you take it off, you will see an impression still there, and possibly only see it in angles of sunlight.
Hope it goes well !!
Old Jan 29, 2006 | 02:46 PM
cuspid's Avatar
cuspid
Wait till a 90 degree day.
Old Jan 29, 2006 | 07:04 PM
0Rick@CTCORVETTE
Former Vendor
I guess I was fishing for a horror story about someone removing them and having problems. It sounds pretty straight forward.
Old Jan 30, 2006 | 05:41 PM
0Rick@CTCORVETTE
Former Vendor
ttt. please.
Old Jan 30, 2006 | 06:01 PM
Speak with Mike76002 here on the forum. He can probably give you some great advice.
Old Jan 30, 2006 | 06:03 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Just rip it off Rick
And if it has BSM - you know the script
Stephen
Old Jan 30, 2006 | 06:15 PM
0Rick@CTCORVETTE
Former Vendor
No BSM's. It's just so.. new Cross your fingers for me.
Old Jan 30, 2006 | 06:22 PM
craig04c5's Avatar
craig04c5
or a warm garage.
Old Jan 30, 2006 | 06:24 PM
0EG@EnglandGreen
Supporting Tuner
I'm putting my engine back together on Saturday, so bring it down and we'll gently apply the hair dryer to it and get it off.
Old Jan 30, 2006 | 06:29 PM
0Rick@CTCORVETTE
Former Vendor
Do I smell a mod party?
Old Jan 30, 2006 | 08:13 PM
nomadman2001's Avatar
nomadman2001
Like I had thought .......... car NEEDS to be warm ........ 40 F isn't good enough ..........IMHO!
Good luck, and oh ya, I have a buffer if you dare once they're gone
Old Jan 31, 2006 | 05:25 PM
0Rick@CTCORVETTE
Former Vendor
I may need a two post lift to take those stripes off along with some other things Thanks for the input everyone.
To Removing vinyl stripes?
