Anybody got an arm extender? I removed the rubber bumper next to the L headlamp so I could get my arm down inside the space where the turn signal socket is; however I don't know how the fixture is held into place and I don't want to break it. Can someone refresh my memory as to where the post is that explains this procedure? A personal email will work too.
Thanks!
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
10 minute job.
that's how I did mine . you will have a 50/50 chance of getting the right bulb unscrewed first . there are 2 in there , and it's kinda tight , but you can get either bulb . not too bad .
Thanks everyone. I'll explore each of those and see which route works better than removing the hood bumper and sticking my arm down inside. (Notice that the owners manual doesn't discuss how to change the front turn signal bulb?)
A complete list of all Corvette lamps can be found at www.sylvania.com. I printed the complete list for my car.
