5 Point harnesses in C5
Been there, done it all, then couldn't stand the forward location of the Hardbar, so pulled it all out until I get a welded in 4 point roll bar....hopefully this spring Then my Schroth 6 point harness goes back in. Several other cmpanies make bolt-in cross bars that fit far enough back that full seat motion is available. If we end up not welding in a roll bar we will choose the R&D crossbar........FYI, from their website ...
R and D racing crossbar
http://www.r-dracing.com/c5crossbar.htm
The C5"CROSS-BAR" mounts high like our C4 bar, with mounting brackets that prevent the bar from rotating and allows the bar to become an integral part of the car. There are anchor straps that run down to the seat mounting studs to insure that the bar does not rotate and makes the bar rock solid. The bar is high enough to insure that bracket flexing is not an issue, but low enough to keep a clear view in the rear mirror. There are no modifications to made to your car, and the "Cross-bar" can be removed in approximately 15 minutes. Also included with each bar is a center mounted camera mount that attaches to the bottom side of the bar. The design criteria of our C4 bar, carries over to the C5 units, in that the seats may be moved and reclined rearward as far as needed. This allows the driver and passenger to travel comfortably during the week and be ready to race on Saturday.
The "CROSS-BAR" is made from 1-1/2" square medium weight tubing and weighs approximately 14 lbs with brackets and hardware.
Brey-Krause seat belt attachments - a
a 6 point belt is what you want not a 5-point. You sit on the sub belts, do not have the sub belt come up from in front of the seat, not secure and safe.
the sub belt of the 5-point tends to pinch the family jewls
so the two sub belts of the 6-point is a better choice. Some guys ware baseball cups for protection too.
I have a bar bolted under the seat so the 5th point comes up. On my rollbar I have tabs welded for the harness so that's pretty easy. Now on a ZO6 there are no upper seat cut-outs I strongly urge you, no matter what type racing get a STERNUM STRAP.
