Another CLB horror story!
Old Feb 6, 2006 | 03:13 PM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Default Another CLB horror story!
Well maybe not HORROR, but definately a PITA! I knew all about the CLB issue from this forum and even took the car to the dealer a while ago to have the recall work done, the problem is I procrastinated about the CLB and never got one.
So you know what comes next: Yep that's me, the guy pushing his Corvette down the road trying to push start (MN6) it after I got the "pull key wait 10 sec..." message. Luckily there was a kind gentleman willing to help me push the car and plenty of space!
As soon as I got in the office, I went and ordered a CLB! Now just to make me feel better, this will solve the problem right? (Plenty of juice, turn key and nothing but a click- after plenty of tries- "pull key wait 10 sec..."
Old Feb 6, 2006 | 03:18 PM
sebringsilver97coupe's Avatar
guys correct me if im wrong but the pull key wait 10 seconds message is related to the column lock but not related to not starting....i think it does start, its just that it will die if you try to drive about a foot or so....thats what ive always heard anyway so push starting if this is correct wont do anything except get good exercise and **** u off. sounds to me like another problem.
Old Feb 6, 2006 | 03:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have me confused. The pull key wait 10 sec, column lock and not cranking are all "SOMEWHAT" different issues. The pull key wait 10 sec, means that the little silver contacts in the ignition switch did not properly read the resistor pellet on your key.
I know for a fact that on my 98 coupe if I got that message and didn't pay attention to it, the car would crank and start but, as soon as you tried to move the car, it wold stall.
The column lock problem means just that. When you insert the key into the ignition and turn it on. the dead bolt inside the steering column does NOT retract and you can NOT turn the steering wheel!!!
If you have the GM Column Lock recall done, and the column locks, The PCM SHUTS OFF THE FUEL and the car will not start or run!
Get the CLB and that will fix that issue!
Sooooo, did your steering wheel LOCK UP?????
BC
Old Feb 6, 2006 | 06:44 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
BC
Old Feb 6, 2006 | 07:29 PM
Batmbl's Avatar
Batmbl
Had the problem last week. Car should start but fuel supply is shut off once car gets to 1.5 mph. I had done both measures - dealer recall and the CLB. Disconnect the battery, wait 30 min. to allow the system to reset and then start again. Worked for me.
Old Feb 6, 2006 | 07:34 PM
troy144's Avatar
troy144
Old Feb 6, 2006 | 10:53 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Pull key and wait 10 sec can be related to a low power situation. Which would make sense if you only hear a clicking sound. Which usually means your battery has gone south and there's not enough power to pull in the starter solenoid. Check it with a volt meter and if it's below 11.75 volts it's probably toast. Or take it to a battery place and have them do a load test. Dollar to a doughnut that's your problem. Keep us posted.
Old Feb 7, 2006 | 08:25 AM
07blackcoupe
Come to think of it, I do remember before I had the recall work done, the car would start and then die. This may not be the CLB and could be the battery. This happened to me last week and when I took it into the dealer, they could not find anything. The guy said that they tested the starter, battery and some electrical things (no lie, thats what the guy said) I took the car home and it took a week to happen again. I have about 75,000 on the car and I bought it at 36,000. I wonder if my IPOD AirPlay charger is draining the battery, I always unplug it when I stop the car??? I may go to Sears and get a new battery today just to be safe...
Oh and to answer a previous question, NO the steering wheel did not lock up. I know I have a MN6, but the first time I took the car into the dealer for the recall, they actually did the wrong recall and removed the locking plate... The second time I took it in they did the recall for a MN6 (I forget exactly what that is) and left out the locking plate...
Old Feb 7, 2006 | 08:44 AM
DeeGee's Avatar
DeeGee
This seems starange.
My first stop would be to check the battery. there are all sorts of weird symptoms when batteries die although I'd not heard the pull key ...before.
If it's still your original AC Delco, with a 99 Vette you're on borrowed time already IMHO.
Old Feb 7, 2006 | 08:52 AM
Dave1998's Avatar
Dave1998
I got this message when my battery was low.
Old Feb 7, 2006 | 08:54 AM
wstory1's Avatar
wstory1
Old Feb 7, 2006 | 09:28 AM
07blackcoupe
How many miles should an original battery last? How can I tell if the previous owner changed out the battery? I think it would be unlikely that they would put in a new battery before 36000 miles...
Old Feb 7, 2006 | 09:37 AM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
With a column lock problem you will get "SERIVCE COLUMN LOCK" on your DIC. Still a good idea to get the bypass and install it though.
column lock
Old Feb 7, 2006 | 09:39 AM
Dave1998's Avatar
Dave1998
Mileage has nothing to do with how long a battery lasts. My 98 went bad at 14,000. miles. There is no way to tell if original battery. Take the battery out of car to a place like Auto Zone and get it tested
Old Feb 7, 2006 | 09:52 AM
07blackcoupe
Alright, since I work in IT I do have some toys laying around the office here and I just happen to have found a "FLUKE 110 True RMS Multimeter". I have never used it before and it has a few settings with a V which I hope stands for voltage. One is for AC and the other is for DC. I am going to guess here and say that I want the one for DC and I would just hold the tester ends to each terminal of the battery and see what the number comes up as??? (please don't confuse me for a union electrician! ha ha)
Old Feb 7, 2006 | 12:08 PM
corvette Mark's Avatar
corvette Mark
Or you could turn the key to the "on" position without cranking the engine and read the battery voltage on the DIC, it should match your fluke reading. Once you crank the engine the DIC will display the voltage output of the alternator.
Old Feb 7, 2006 | 12:18 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
what he said
sounds like your battery is toasted
To Another CLB horror story!
Old Feb 7, 2006 | 12:38 PM
07blackcoupe
What fun is that???
Old Feb 7, 2006 | 12:49 PM
Stock Man's Avatar
Stock Man
Right on!!
Old Feb 7, 2006 | 01:24 PM
07blackcoupe
Going out for lunch now, I hope it starts!
