Enclosed Vette Trailer
They always tell you that since all you are hauling is a 3200 lb car, you have LOTS of leeway.
Now the math. 24 ft trailer will be 2800-3500 lb empty.
Say the average is 3200 lb empty + 3200 Vette = 6400 lb, with 600 lbs to spare.
Add the spare 65-75 lb.
Add the awning. 75-100 lb.
Add the tool box 75-100 for small, 400-500 typical roll-around.
Cooler full of stuff - 75
jack 50
chairs 50
See how it all adds up? And with this big empty box behind you, the tendency to fill it is greater than you can imagine.
You will like your trailer much more if it is a 10,000 GVWR with 6000 lb axles (12,000 cap) than one that essentially is an aluminum box built on the typical open trailer.
Front tie downs, 3 feet infront of the vette, and rear tie downs 2 feet behind the vette.
the other reason for a 24 foot is you can ballance the car over the axles vs a 20 foot the car is too far forward of the axles and you have way too much tounge weight on your tow vehical.
Shorter trailers also may not have the load capsity for a 3200 lbs vette
the trailer tires also may not have the load capasity of the trailer plus the vette. need at least 7500 lbs minimum more like 9000 lbs.
The other questions is what is your tow vehical??
As far as length and weight Hallmark has a 20' 22' and a 24' that can take 12K weigh more than you will ever need. I think 20' is a little small but 22' is fine as is 24'
Beautiful truck!!!
Get some t-hooks fro a tow truck supply place and 5000 lbs straps
use the X patttern
X
X
left front d ring on trailer deck to right front jacking puck hole with t hook in
Right front to left front jacking puck hole and
the same for the rear
and an older pic of the rear straps
jack 50
chairs 50
Mark has a great point here. A few other thing to consider are the trailes tires your tow vehical.
Trailer tires on 20 to 22 footers and most 24 footers are not load rated for 7500 lbs or more.
No matter what the Gross Vehical towing capacity is, take 80% of that amount and that is really the safe max towing load.
So with Marks example above of a 10,000 GVWR trailer that means one needs a 12,500 GVWR towing capcity or a 3/4 ton truck minimum.
I have a 24 foot enclosed with 6000lbs axles but use a 1500HD for towing. It is OK, just OK, for short hauls of 100 miles on back roads but not major 4 lane roads. When am 18 wheeler passes me the suction is not good
my truck and trailer start the wiggle dance, I have learned to left brake in my truck, left foot on the brake to slow the trailer and right foot on the gas to accelarate to stop the dance and straighten the rig out. Needless to say I am looking at 1 ton doolies now.
use the X patttern
X
X
And this talk of half ton trucks can't tow, hah!
Remember when people used to tow with CARS????? Do you think this picture has a
Class IV equalizer hitch, anti-sway stabilizer, electric brakes, and so on?
Now, yes, if you are going to tow a 3500 lb Corvette in a 3500 lb enclosed trailer
and carry 2000 lbs of stuff (easier than you think), then yes you need a vehicle that
can tow 10,000 lbs. But many can tow on an open trailer and be fine.
To bad they don't build cars that are worth a darn anymore that can carry or tow
something bigger than a suitcase.
