Need Torque Settings
Old Feb 14, 2006 | 09:22 PM
5th Vette's Avatar
5th Vette
Default Need Torque Settings
Can anyone provide me with torque wrench settings for the following items?
Rear sway bar bushing straps
Brake Caliper brackets
Alternator/power steering pump bracket
Belt Tensioner/idler pulleys
Thanks in advance for any help that you can give me!
Old Feb 14, 2006 | 09:34 PM
RedWolf's Avatar
RedWolf
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09
Did you go through the great "sticky" at the top of this forum page about weights and measures? I went throught it quickly and did not see those particular items but they may be there.
Old Feb 14, 2006 | 09:35 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Rear sway bar bushing straps. upper bolt 49lbs, lower 70bs
Brake Caliper brackets. 125 lbs (plus red lock).. calipers themselves. 23lbs
Alternator/power steering pump bracket. 37lbs
Belt Tensioner/idler pulleys. 37 lbs
From the '98 service books...
Old Feb 14, 2006 | 09:42 PM
5th Vette's Avatar
5th Vette
Thanks for the info! I need to buy those manuals.
Old Feb 14, 2006 | 09:46 PM
devnull's Avatar
devnull
Anytime bud... Forgot to tell you to use blue thread lock on the caliper bolts (red on the caliper bracket bolts)... (disclaimer: GM will tell you to replace them instead)
Those manuals are a life saver....
Old Feb 14, 2006 | 10:16 PM
2KFRC5's Avatar
2KFRC5
Default Save for future reference
http://www.metricchemical.com/C5torque.pdf
Compliments of David Farmer Racing
Old Feb 15, 2006 | 08:44 AM
devnull's Avatar
devnull
Originally Posted by 2KFRC5
(nice)
Old Feb 15, 2006 | 01:07 PM
MR1911's Avatar
MR1911
Very nice
I printed it out and am gonna put it in my glove box
Old Feb 15, 2006 | 02:08 PM
rws.1's Avatar
rws.1
clean those caliper bolts and bracket bolts with a wire brush prior to re-use and be sure to use the threadlocker...
Old Feb 15, 2006 | 02:13 PM
rws.1's Avatar
rws.1
In a previous post a member printed out the torque specs, laminated them and stuck them on the side of his tool box
Old Feb 15, 2006 | 04:38 PM
LoneStarFRC's Avatar
LoneStarFRC
Almost positive these are 37lbft. I changed these in the past and that's what I remember the torque was. HTH
To Need Torque Settings
